Question about Dacor Ovens
What does f8 on dacor self cleaning oven mean
Michael Masters
  • 6,784 Answers
HI. This will generally be an issue with either the wiring at the door switch mechanism, or the door switch itself. Check the door lock switches and wiring. If the wiring is connected well, this will lead to a failed door lock switch mechanism. Use my procedure below to confirm switch failure.
Before repairs or further testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. Once access is gained, set the latch to the "clean" position and test for circuit continuity at the terminals of the switch with your VOM's ohmmeter function. If there is no continuity, the switch is faulty. Use cuation when testing.
Posted on Jan 05, 2010
Testimonial: "thank you very helpful "
F8 alert. What does this mean? The clock and "cancel" buttons work, but no heating buttons work, and self-clean will not operate.
F8 code means your door latch assy needs to be replaced, them you have options:
1. Turn it off on the circuit braker
2. Replace the door latch.
It will continue to try to lock itself most likely, as door latch micro-switch logic is messed up.
Hope helps.
Jan 03, 2011 | Dacor ECD230 Epicure Electric Double Oven
Oven started making a clicking noise after I started the self-cleaning process. Continued until "F8" flashed next to the clock. When canceled was pressed, the clicking started again. As a...
F8 means a fault on the door locking switch.
Something may be preventing the door lock from operating properly.
The solution is to have the door lock switch and wiring checked over.
Dec 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
I pressed the self clean option and the oven locked but every two minutes an alarm sounds and the code F8 appears. The cancel option stops the alarm temporarily. How do I either clean the oven or cancel...
F8 code means your door latch assy needs to be replaced. Two options:
It will continue to try to lock itself most likely, as door latch microswitch logic is messed up.
www.oc-repair.com
Feb 10, 2010 | Dacor ECD230 Epicure Electric Double Oven
Put oven through self clean for 2 hours. Oven
What has happened is IF the temp gets to hot in the electronic controls area, an in line fuse/limit burns out and shuts down everything.
I have a DACOR tech sheet HERE
So what I think is happening is the in line fuse in the wiring harness could be blown. You won't know till you or someone checks.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 15, 2010 | Dacor Ovens
I don't know how to clean the oven
You should have a function switch that says " self clean ". Normally, all you have to do is turn the control on to "self clean" and let the oven do the rest. It will take about 3 hours or so to complete the cycle.
Jan 30, 2009 | Dacor ECS127 Epicure Electric Single Oven
Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Sep 22, 2008 | Dacor ECS230 Epicure Electric Double Oven
Oven not working
15
problem
8. door will not open.
9. oven will not heat after Self cleaning.
possible Cause
oven is in Self-clean mode.
time of day is not set due to power failure.
oven settings are not correct.
remedy
if oven is hot, door latch will release
automatically when oven temperature
falls below 390˚F at end of cycle.
if Self-clean was just selected
and the oven is still cool, press
“caNceL•SecuRe” to turn off Selfclean.
the door will open in about 30
seconds.
Press “cLock” touch pad, then press
“tiMe•teMP” pad to set correct time of
day.
follow mode selection and clock settings
as specified in the oveN oPeRatioN
section.
oven will turn on automatically
at preset time. if desired, press
“caNceL•SecuRe” touch pad to cancel
out of delay timed mode.
Troubleshooting Guide (Continued)
Important:
If a Failure Code is displayed, the oven will beep continuously until the user presses the “CanCel•seCure” button. the oven will not heat
after a failure. Call a qualified appliance technician to repair the oven.
Oven Failure Codes
Clock Display Cause
f0. touch pad is stuck in depressed position.
f1. Relay circuit failure.
f . oven temperature exceeded the clean runaway temperature (Self-clean mode
only) or the cooking runaway temperature (cooking modes only).
f3. Short circuit in the oven temperature sensor.
f4. open circuit in the oven temperature sensor.
f6. failure in the eePRoM check comparison. (only time of day and timer will
operate.)
f7 failure of the Self-clean automatic door latch circuit.
f8. failure of the door latch motor. occurs when the motor runs for two minutes
without the door locking in Self-clean mode.
befOre yOU Call fOr servICe
No maintenance, other than the Care anD CleanInG
InstruCtIons identified in this use & Care manual, should
be attempted by the owner/operator. all other maintenance and
service must be performed by a qualified appliance technician.
first, review the recommended checks listed in the preceding
troubleshooting Guide. then, be certain that the appliance has
been installed properly and is being operated correctly. familiarize
yourself with the warranty terms and conditions listed in the
proDuCt WarrantY section.
if the above checks have been completed and the problem has
not yet been remedied, call your local authorized dacoR®
service representative. your dealer can normally provide the name
and telephone number of the nearest service company.
prOdUCT maInTenanCe
If yOU need servICe...
dacoR® works diligently to ensure your satisfaction when
service is necessary. However, if you are not completely satisfied
with the service provided, contact the company that performed the
service and express why you are not pleased. Normally, they will
be willing and able to resolve the problem.
if the service agency is not able to respond effectively, call or
write the dacoR® customer Service department. the phone
number and address of this department are listed on the inside
front cover of this manual. Please include your telephone number
if you choose to write. we will then do our utmost to assure your
happiness and satisfaction.
Here is a snipet from www.dacor.com
You can view the manual there by enter ing your oven model number.
Feb 22, 2008 | Dacor ECD230 Epicure Electric Double Oven
SELF CLEANING DOES'T WORK
"F8" ERROR MESSAGE. This indicates a door latch failure.
Jun 25, 2007 | Dacor ECS130 Epicure Electric Single Oven
Ovens Logo
806 people viewed this question
Top Dacor Ovens Experts
Paul Bade
Vincent G
Vincent G
ray gallant
Are you a Dacor Oven Expert? Answer questions, earn points and help others
