Question about Canon SmartBase MP390 All-In-One InkJet Printer
How do I reset waste ink tank full on Smartbase mp390?
Don Farrell
    Genius:
  • 1,018 Answers
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Posted on Jan 05, 2010
My Canon MP390 Printer has come up ''Waste Inn Tank nearly full'' What should I do
CANON printers "compute" the "fullness" of the waste-ink container, based on the number of pages printed, and the "density" of the ink on each page. So, this calculation has produced a "nearly full" prediction. Take the printer to a qualified technician.
They will empty the waste-ink container, and "reset" the electronics in the printer, back to "zero-per-cent-full".
5helpful
2answers
Canon mp 390 waste ink near full
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
2answers
A message saying waste tank nearly full comes up and i need directions to fix it?
Hello. this message indicates that the computer merely has to be reset [canon is hoping you will take your printer to them for a costly tuneup] here are the steps to reset your counter:
Manual Reset procedure for waste ink tank full error in Canon Smartbase MP730 printers:
  • Hit the “menu”: Key
  • Hit “Copy” Key
  • Hit “#” Key
  • Scroll thru the menu headings until you come to “Test Mode” - 12th heading
  • Hit the “3′ button- this will bring up Eeprom Clear
  • Hit “0′ button
  • Hit the “Stop” button
Here is a link where you can download the entire service manual for $4.00. http://www.tradebit.com/filedetail.php/4546475-canon-smartbase-mp360-mp370-mp-360-370
3helpful
Waste ink near full flashing
Manual Reset procedure Waste Ink Tank for Canon MP390:
  1. Start with printer on, press additional functions, Scan, Copy, Scan. Now you should be in service mode.
  2. Select Test mode (must be the last available selection).
  3. Select #8 Printer Test, it will start cleaning then it will come up with some other option: push the + or - button until it says 8-3 then hit the select button
  4. The menu will now say EEPROM Clear
  5. Select Ink count which is option (0) and press set
  6. Press Stop/Reset Followed by the power button and then wait for it to restart.
Waste ink tank nearly - message
it won't stop until the ink absorbers are replaced and the error reset in canon diagnostics. A shop repair, around $100.00
Smartbase MP390 Printer - error code #345
"waste tank full" alarm; you may need to reset the waste tank counter.
Try:
Resetting the Waste Ink Volume Counter
1) Enter SERVICE MODE.---
By pressing Menu-Copy-#
2) Select TEST MODE.
3) Select [8] PRINTER TEST in TEST MODE.
4) Select 3. [EEPROM CLEAR].
5) Select 0. [INK COUNT].
6) Press the [OK] key.
7) Press the [Stop/Reset] key (returning to the state of 3)), and then press the [ON/OFF] key.
1helpful
Error ##343 and it didn't print anything Orange light below screen has been flashing, screen message "Waste Ink Nearly Full". No idea where waste ink container is kept? Have changed cartridges. Now saying...
hope it helps
cheers
Canon Smartbase MP390
hope it helps
cheers
Canon SmartBase MP390 All-In-One InkJet Printer Logo
old marine
old marine
Ekse
