Question about Zooper Cool Zone Buddy Stroller
Replace seat cover after cleaning
Have just washed seat cover and need to put it back on to frame correctly.
How do you remove hood?
Posted by gillpn on
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 274 Answers
Posted on Jan 06, 2010
How do i replace the cushion in a buick lacrosse 2008
You have to remove the seat from the car, turn it over, and cut/remove all hog-rings holding the cover to the seat and pull the cover and cushion off. Set the new cushion in the cover, place it back on the seat frame, and hog-ring it back in place at the same points the original hog-rings were. Put the seat back in the car.
Nov 13, 2017 | Buick Cars & Trucks
Is there an alternative seat for the Jazzy? We are trying to find a less plush seat so that the seat will be lowered enough for a Little People user. She can not get up in the seat due to disability.
Yes, this can be accomplished by lowering the seat or raising the foot platform.The cushioned van seat can be removed from the seat frame and a wood platform covered in vinyl can be substituted. Sticky back Velcro strips are put on the vinyl cover to hold the cushion. The sticky back Velcro attaches to the vinyl covered wood platform and will mate up with the Velcro on the bottom of her existing cushion. The back cushion can be left in place. Pride makes this flat platform for all their models. You would need to specify the dimensions and style of the original seat to order the custom one. There is a manufacturer sticker under the seat with a series of numbers you can give to customer service at pride to help get the correct replacement platform. You can also raise the foot platform on the vertical adjustment post or attach a foot platform to the top of the footplate.
If this modification is not covered by insurance you can have a handyman remove the cushioned van seat and hack off the cushioned foam, springs and vinyl. He could then cover the wood with a durable material or sand and paint it before reinstallation.
Hope this helps.
Feb 27, 2014 | Pride Jazzy Select 6 Indoor Power...
How to remove a back seat from 02 toyota avensis
Hi, peel the cover from around the seat frame so that the shoulder strap hold the cover on to the seat.
Extend the set belts to their maximum length and recline the seat as far as possible.
Looking at the seat from the front, put your hand in the gap between the reat of the seat (bit that reclines) and the fromt of the fixed base (by the red dome and the instructions).
On the bit of the seat that reclines there is a 'door' that opens to reveal a metal clasp that the ends of the shoulder straps fix to at the top and the ****** belt at the bottom.
Unhook the looks from the shoulder straps from the metal clasp.
Pull the shoulder straps through the back of the seat upright. You can now pull them through the cover which is free for you to wash.
Thank you.
Jun 06, 2012 | Cars & Trucks
Need to replace sunroof..
you need to replace glass or is it leaking if leaking then you have to remove upper seat belt covers pop off remove bolt 14mm and the trims on upper pillars pry off carefully held in by clips remove covers on interior light at front where sunroof switches are there are screws by bulbs disconnect connector remove center light cover and screws disconnect connector with clean hands remove rbber trim around sunroof opening and plastic cover on each side of sunroof glass held on with plastic screw clips then remove four 10mm nuts lift sunroof glass out of car remove cover and screws from rearview mirror all plastic trims around headliner move pass seat forward most and flip back rest all way down roll pass window fully down then slide headliner out of car now you can remove electrical connectors and remove water flow hoses from sunroof unit remove 8 12mm nuts holding frame to roof remove through door you will see the track sunroof slides on remove nuts along problem is silicone between track and frame is deteriorated lift track clean replace silicone reattach frame to roof dont put trims or liner in till test connect switches and glass to frame make sure sunroof works and closes fully then go through car wash to see if leak is fixed
Jan 13, 2011 | 2001 Subaru Legacy
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
Removing seat cover maxi cosi priorifix
To be able to remove the seat cover from your seat you have to 'unhook' the seat belts at the back of the seat:
First extend the seat belt to the maximum length.
Then put the seat at the maximum recline.
At the back of the seat-'shell' you will then see a metal hook that hold the shoulder straps: unhook and pull forward.
Reassembly is just the reverse.
A few more tips when removing the cover from a PrioriFix: take care not to damage the white extruded foam when pulling the belts forward and when taking off the cover. When the foam is not protected by the padding it may easily snap.
The seat padding is cold wash only and no spin-dry, otherwise the seams may loosen.
Please don't hesitate to use the contact form at http://www.babycare.nl if you need any further assistance.
With kind regards,
Babycare.nl Sales Desk,
Erwin de Raad
Jun 21, 2009 | Maxi-Cosi CabrioFix (Black Reflection)...
Washing techno xt
Remove the hood from the stroller and wash it by hand in the sink or bath tub. They usually clean up very well. Open the hood up and hang to dry or put it back on the stroller with the hood fully extended and let it dry. Just remember not to fold the hood back until its completely dry so that it doesnt mildew.
Mar 24, 2009 | Maclaren Techno XT Wisteria Umbrella...
Stroller pad cleaning
You can remove the seat pad by unsnapping the two straps on either side of the bottom of the pad (where it covers over the metal frame). Then just thread the buckles through it. As far as the rest of the fabric such as canopy or fabrice sides, no luck. I got this stroller used and wanted to wash it all. I ended up just putting it (minus the removable pad) into my shower and washing it with the shower head. Then I got a Mr. Clean magic eraser and cleaned up the plastic parts. Now it looks so good!
Hope this helps...
Jan 03, 2008 | Evenflo Aura Traditions Travel System...
How do i get the seat of to wash?
I was able to find an online instruction manual for this stroller. From that manual, I was able to find the following instructions for removing the seat for cleaning.
"10 REMOVING AND REFITTING THE SEAT COVER
Remove hood from stroller if fitted.
A Twist shoulder strap end buckles and feed through holes.
B Feed waist and crotch straps through holes.
C Unclip seat cover retaining straps.
D Unfasten seat fabric from handle tubes and seat base.
E Slide fabric from seat back and base.
F When refitting seat fabric, insert seat back support tubes
into fabric slits.
G When refitting seat fabric to seat base, loop fabric flap over legrest
strap and pass crotch strap buckle through both holes in seat fabric
and then hole in seat base.
H When refitting shoulder straps, twist buckles and feed through holes."
Dec 18, 2007 | Maclaren Quest Mod Stroller
Zooper Cool Zone Buddy Stroller Logo
348 people viewed this question
Top Zooper Baby Gear Experts
Marvin
Marvin
Paul Carew
john h
Are you a Zooper Baby Gear Expert? Answer questions, earn points and help others
