Beko WMA10 W Washing machine. Power light on but thats it.
I have a beko WMA10 W Washing machine. I have had a few problems over the past few weeks. Firstly there was a really loud screaching noise during the spin cycle, then the cycle would stop half way through and only continue if I switched it off, then reset it. Now the power light comes on, but that it is, nothing else happens. Is this a easy repair or should I invest in a new washing machine?
Posted by willywilson2 on
Anonymous
    New Friend:
  • 95 Answers
Sounds like the main bearing,it would be cheaper to puchace a new mc
Posted on Jan 05, 2010
Anonymous
    New Friend:
My wma10 washing machine became noisey on spin so ive changed the carbon bushes and now it doesnt do the the cycle or even wash were have i gonee wrong
Posted on Jan 18, 2010
Beko washing machine EA error
There is no EA code.
https://capitalrepairs.co.uk/news/beko-washing-machine-error-codes/
Code EA on my beko washing machine? how to fix it
Beko washing machine error code e5
Error E5. This can mean a number of things but usually involves the machine not draining properly and taking too long to go through its cycle or not spinning. There could be blockages or problems with the pump/filter or an issue with the control board.
https://www.washingmachinerepairservices.co.uk/beko-washing-machine-error-codes/
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Beko wm5100 w won't agitate but is filling and empting
A week ago I had similar problem with beko wm3552m model (~ 10 years old). In may case was enough to replace the carbon brushes of the engine. It took me some time to figure out where they are locates, so I put some pictures on the net:
how to replace carbon brushes beko washing machine wm3552m
3helpful
Beko wma1510s washing machine dial problem
my beko wma 1510s will not spin and is heating up
2answers
Washing machine wont spin (beko 1512 s)
Hi if your beko 1512 s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Washing Machines Logo
Top Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
