Slight ghosting and color alignment problems
My Projection TV Mitsubishi VS-5003R has some ghosting with the contrast and brightness on high. Also, having very slight blue, red, and green alignment problems. Is there potentiometers I can adjust?
Posted by djaries1 on
jairo sanchez
    Sergeant:
    Champion:
  • 276 Answers
Comvergencia that reviews the misaligned with the remote control and traps
Posted on Jan 05, 2010
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
My Mitsubishi VS-60621 seems to have a convergence problem
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Mitsubishi VS-60621 60" Rear Projection...
Mitsubishi VS-5003R close caption
That is so old I can't find specs on it.If you have a cable box, Directv or Dish Network you can turn on cc from the Receiver box or even an antenna converter box
Mar 29, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Wd-62825 mitsubishi dlp tv
Had the same problem. Service replaced the lamp engine. It did help.
Dec 18, 2008 | Mitsubishi WD-62825 62" Rear Projection...
S.O.S anyone out there
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • No Audio/Video - makes a chirping sound.
Example Photo:
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Sep 03, 2008 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi VS-50501A convergence problem
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Symptoms
Example Photo:
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Good Luck, big IRISH.
Apr 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi TV; Model No. VS-45607
Straight from The Mits website
Intro Year:
2000 Chassis:
VZ8 Height:
48" Width:
38 3/8" Depth:
22 1/4" Features:
The Silver Series includes Mitsubishi's most cost-effective projection televisions, yet they outperform by wide margins many of the more expensive models of other manufacturers. With their superb picture, wide assortment of inputs and features, and highly capable system remote control, the Silver Series sets new standards for the entire industry. These exceptional performance features include the following: DIAMOND VISION Optical System 3D-Y/C Comb Filter: Delivers crisp color separations and smooth picture texture. Dynamic White Balance: Ensures color accuracy at all brightness levels. Three S-video Inputs: One in front and two on the rear panel, allowing quick and easy connection of a high-quality camcorder or video game, while simultaneously providing connections for home theater system components such as a digital satellite system and an S-VHS VCR. Component Video Input: Provides the best possible picture quality from a DVD player. 64-Point Digital Convergence Adjustment: Easy to use and provides precise color alignments. 2-Tuner Multi-PIP with Split Screen. 5-Layer Multibrand Remote Control: Allows the operation of a satellite or cable box, a VCR, a DVD player, and an AV receiver-all from one keypad. Intelligent Room Illumination Sensor (IRISþ): Automatically reduces brightness and contrast for a more pleasant viewing experience in a darkened room. Weight (approx.) - 178 lbs Power consumption - 240W
Feb 19, 2008 | Mitsubishi VS-45607 45" Rear Projection...
TV shuts off with high color images . Example: explosions,bright lights etc
Normally, the screen control being up a little to high, would cause this problem. If no one has worked on this unit when it started may be a sign of something else, for example, the 200 volt line may be running a little low. Check the brightness and contrast for starters and if that doesn't help, then, the screen control would be my next step. Hope this helps.
Jun 03, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
