Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Fisher Paykel Fridge. Access to fridge fan.
Fisher Paykel E521T Fridge. I think the cabinet fan has stopped working. I have the back of the freezer cabinet off to keep an eye on the freezer fan but despite having the parts manual and a few hours trawling the web, I can't find out how to get to the fridge fan. Anyone know?
Posted by chrismoore34 on
Richard
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
My fridge is 11 years old and recently had the same problem; the freezer was cooling well, but the fridge compartment was not cooling enough. I searched the Web a read most answers. I thought the fan was faulty, but in fact it wasn't (the fridge has got 2 fans, one for each compartment, and they look very similar, the part number on mine was 883340). The whole problem was a build-up of ice in the condenser unit that is at the back of the freezer compartment. What happens is that the ice blocks the passage of air the fan for the fridge compartment. This of course stops the cool air circulating to the fridge compartment. I was able to repair the fridge an it is now working perfectly. This is what I did:
1) Removed everything from the fridge, food, shelves, the lot.
2) I made sure the fan for the fridge compartment was okay, by connecting it to a 9V battery; the fan was okay. (I did this because after reading the posts I was convinced the problem was a dead fan, but you can skip this step if you can hear the fan spinning and think it is okay). To check the fan, remove by pulling the toll plastic cover that fits below the smaller plastic cover with the temperature indicator. This cover is very flexible and flimsy, start pulling from near the bottom and continue along the right side, flexing it as you go along, until it comes free (there is an insulating plastic foam moulding underneath that comes with it). As soon as you remove this cover, you will see the small fan and the plugs. Unplug the fan's connector (it has a small lock you need to press) and wire it to a standard 9 volt battery. CAUTION: observe polarity! The battery positive terminal MUST be connected to the RED wire (or the fan burns!). If the fan is bad, you can remove it very easily by inserting 2 finger inside the white plastic holder, pushing the fan in (the fan is held with 3 very elastic thin silicon bands, that do not break) ,hooking the holder from the inside edge with your fingers and pulling. It will just come out through the slot. (I did this, but then had some problem in getting it back in place. I finally left it in a near flat position, but not quite as flat as it was. Nevertheless it works okay).
3) My fan was good (I wasted a lot of time doing this), so next I shifted my attention to the freezer compartment. I then noticed that the plastic cover at the bottom of the compartment was half dislodged from its proper location, all covered on ice. I removed the cover, breaking the ice that held it with care. This cover is difficult to remove, there is a lot of pushing and pulling, so be prepared and patient; do not break it (mine came out with a small locking leg broken, but it did go back in place without any problems). I then checked the second fan, that is on this cover; it was also okay.
4) As soon as I removed the cover I saw the problem...ice everywhere! I reached for the house hair drier and after about one hour it was all gone. Note that most of the problem ice is behind the condenser (small radiator looking aluminum frame, that should be left alone. Do not move, push or twist it).
5) once all the ice was removed, I the carefully pushed the radiator back in place at the bottom of the compartment (it just fits and had been displaced by the growth of ice), and replaced the plastic cover.
6) and voila! my fridge was again working perfectly. About 3 hours flat.
Posted on Mar 01, 2012
neil
    New Friend:
  • 30 Answers
Its quite simple remove all shelves inside refrigerator compartment, simply remove cover ( located underneath diplay panel (will unclip) and then remove the display panel and looking up towards the roof you will then see provisions compartment fan ...try this
Posted on Jun 08, 2010
My fisher and paykel active smart fridge E521T is playing up, the fridge don't work no more but the freezer is fine? Any help would be great
check the fan that blows the cold air from the freezer to the fridge,this is a common fault it is located between the fridge and freezer compartments
I recently scored a bargain Fisher Paykel stand-in fridge/freezer because my original fridge developed a fault. sadly the stand-in Fisher Paykel N405T has an issue of its own, the freezer doesn't really...
Yes ur correct. the fan can be accessed by removing the back panel wall from ur freezer dept. sometimes u will have to remove the bottom panel first a couple screws are all it takes
2answers
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
1helpful
3answers
Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
1helpful
E521T
close freezer door, open fridge door and press the mode button
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
Top Fisher and Paykel Refrigerators Experts
Dan Webster
Dan Webster
Gil Shultz
Jay Finke
Jay Finke
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
