Onkyo TX-DS838 Receiver Logo
Posted on Jan 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Onkyo A-809 amplifier.... i want to get this amplifier mannual &Guides.
Lee A.
Level 3:
  • Master 4,472 Answers
  • Posted on Jan 05, 2010
Lee A.
Master
Level 3:
Answers
4472
Questions
0
Helped
1083934
Points
12549
Http://safemanuals.com/user-guide-instructions-owner-manual/ONKYO/A-809-_E
Follow the link and you can download the manual for free.
thank you,
Lee
I have Onkyo TX-NR709 is it possible for me to use my BOSE 809 series 3 as my front speakers, I have PA Behringer EPX2800 can I connect all these?
Hello, You can use all three of these together. You could use the front (red and white) preout on the back of the 709 which will connect into the red and white input on the amplifier. Then you will connect the Bose speakers to the amplifier. Thanks, FJD
Can a Onkyo tx sr604 receiver be used as a pre amp?
Yes. You can use the Line Out, or Pre-Amp output into another receiver or amplifier. The receiver or amplifier you use as the amp, will need to have a volume control, as the line output coming from the TX SR604 cannot be varied.
If you have any further questions, please visit my website at audioserviceclinic.com and contact me there.
Thank you.
Onkyo Amplifiers & Preamps
Hi ,try cleaning your volume control ,here is a video so you can DIY or contact your local service. :)
Onkyo M-282
check your amplifier output speaker impedance requirements..
example: 8 ohms...build a speaker 8 ohms in parallel or series connection..
check the impedance using ohmeter ..you must reach the required impedance..
use 1 cell battery to check if you speakers are in-phase...if one speaker did not ..reverse connection and check again ...to give the good sound...hope you understand my english..:)
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
I have a Panasonic TH-42PZ700A High Def TV and a Panasonic 160gig DVD Recorder. They both have 1 optical audio output each. I have an Onkyo amp which has 1 optical input for audio. How can I have 5.1 dolby...
Dear ritchiewayne,
Please connect optical out of the DVD recorder to the input of panasonic TV. Next connect TV's optical out to the input of Onkyo amplifier. connect speakers to the out put of Onkyo amplifier.
ramesh22
4answers
Onkyo Integra A-809 input selector switching by itself
This is not an IR problem. Could be just loose connectors and dry joints. You'll need to open the unit and visual inspection of the PCB and connector for abnormality.
Good luck.
2helpful
6answers
Onkyo integra a-809 amplifier
Use Deoxit on the switch. It is a contact cleaner available at Radio Shack and Fry's. Exercise the knob well. It worked for me on my newly acquired Onkyo A809.
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
John
John
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
