Acer (KV.16X04.007) DVD Drive Logo
Question about Acer (KV.16X04.007) DVD Drive
My dvd drive wont eject since i ripped cd's on windows media player it froze and then wouldnt eject te cd
Posted by brentmacmkin on
Anonymous
    New Friend:
  • 79 Answers
Well on the CD drive u will find a pin hole which is used to eject the drive tray manually so use a pin and try to eject the CD.
good luck
Posted on Jan 05, 2010
jimod4343116
    New Friend:
  • 17 Answers
Sometimes the hook that retains the tray will not release unless the tray is pushed inward slightly while trying to eject - poor design.
Posted on Dec 15, 2014
2answers
Cant play cd audio but will play dvd
ALL CD's or just one CD? Depends on the file format and the Media Player. Have you tried another Media Player? Does the CD work in another Computer? Did you make the CD? What is the Media on the CD?
1helpful
I can not copy an audio CD into my computer!
You can't copy Audio CD's to a hard drive. The .cda format is meant for only CD's. You have to rip them to some other format for a hard drive to recognize (such as .wma or .mp3).
How to rip an Audio CD using Windows Media Player
QUICK RIP
You can do a quick rip if the "AutoPlay" menu comes out when you insert a disk in your computer's DVD/CD drive.
One of the options under AutoPlay is to "Rip Music From CD (using Windows Media Player)" which will automatically launch Windows Media Player and the Rip menu. Make sure you uncheck the "Always do this for Audio CDs" box so your computer doesn't automatically launch the Rip menu every time you insert a CD (i.e. in case you just want to listen to a CD next time).
Start the ripping process by clicking on the "Start Rip" button (e.g. in Windows Media Player 11, for example, it's on the lower right once you're in the Rip menu). You'll also have an option to use your Internet connection and have Windows Media Player automatically find details about the CD you're using so you don't have to fill out album and song details yourself (for this tutorial, let's assume that you're not connected to the Internet, which means you'll end up with an unknown album with unknown songs). You'll know the ripping process is done once all the songs show "Ripped to library" under "Rip status."
By default, Windows Media Player will rip your tunes in WMA format and save it in your "Music" folder. You can access the folder by clicking on the Windows logo at the bottom left of your computer's screen. For Windows XP, for example, it'll be the "Start" button. For Windows Vista or Windows 7, it's the circular icon with the Windows four-panel graphic that looks like a waving flag.
Clicking the "Start" button in Windows XP will bring up a menu box with "My Music" as one of the options. For Vista, clicking on the Windows button will bring up a menu with "Music" as one of your options. Anyway, clicking on either of those choices will open your music folder. Look under Unknown Artist and you should be able to find the Unknown Album you just ripped. Once you find the songs, you can rename them one by one.
To do a normal rip, let's go to the next step.
NORMAL RIP
For more options, like changing your ripped music's format to MP3 or changing the folder where you save your music, you can do a normal rip.
Start by launching Windows Media Player yourself via the "Programs" option by clicking on either the "Start Menu" tab in Windows XP or the Windows logo in Vista or Windows 7 (both at the lower left of your screen). Insert your music CD. (To simplify things, just cancel and close down the "Autoplay" menu in case it shows up.)
Once you're in the Rip menu, click on the Rip tab to bring up a list of options. "Format" lets you pick between Windows Media Audio formats, WAV, and the more popular MP3 format. The WMA and WAV both have "lossless" format options, which means the music will be ripped with no loss in quality. The MP3 format, meanwhile, offers wider compatibility with portable music players and smaller file sizes but sacrifices a certain amount of quality depending on the bit rate of your file. This brings us to the "Bit Rate" button, which basically lets you pick the quality of the rip. The default for bit rate is 128 Kbps. Note that the higher the bit rate you pick, the better the quality you'll get, but you'll also get a larger file size.
========this worked for me and should work for you too, please let me know if it helps========
CD drive functions lost.
While it sounds like the drive is failed you can try this:
power down system
eject the physical drive from the chassis (there should be a lock release on the back of laptop)
slide the drive back into the chassis
power on the laptop
After windows starts up - go to my computer and see if the drive is present.
Keep me posted - we can try something else a little more intense
1helpful
2answers
Copying a CD - How do I go from the DVD player to the hard drive and back to a blank CD? It's a Toshiba L300
Pop your music CD into the drive and open it with Windows Media Player. In Media Player there is an option to "Rip" or "Copy" the CD.
Choose one of those options and copy the CD to the hard drive. After its been ripped you can then select the burn option and copy it to a blank CD.
It's as easy as that, however you cannot do this with DVD's just music CD's.
Please post back if you require anymore advice.
Regards.
I just had an internal super multi dvd rewriter GH22 by LG installed, but don't know how to use it. where can I get some instructions ? Why won't it play my music cd's?
in order to play music, it has to be pluged into directly into your sound car iva a special 4 pin conector (only one drive can be pluged in at a time). copying files is easy, just drag them into the drive folder just like copying stuf to a flash drive. but instead of pushing the eject button, right click in the folder ans select eject. this will start the copy procedure. to copy music use the rip tab in windows media player. for copying dvds you will need a third party program. i recomend VLC media player, it's available free from download.com
1helpful
2answers
When i try to burn on hp1040e dvd burner it wont recognize the dr
you may not install the proper drivers of your burner, install it again and use some other burner application like nero cd burner etc.
Sansa fuze 2gb some sync'ing some not on windows media 11
Go into Windows Media Player --> click the black arrow under the Rip tab --> Rip Options --> Format --> Mp3
Now re-rip the songs from CD
Delete the versions of the songs that you just ripped from your mp3 player
Now Sync the newly-ripped versions in mp3 format
You should be good to go now
-Tha Mp3 Doctor
My hp dv900 recognizes and plays a movie dvd, but windows media player won't rip it.it tells me to insert a blank cd
are you using the right btype dvd or cd for ripping and is it a dvd drive
or just a cd drive
1helpful
My acer extensa 2300 dvd-rw drive wont work?
Try this; Goto > DEFAULT PROGRAMS > SET YOUR DEFAULT PROGRAMS > and check the settings for each media application you have on your system.
If you just use Windows Media Player then do this aswell > open windows media player, > TOOLS > OPTIONS and go through the various tabs and check the BURN & RIP options
If They dont work check that the device is installed correctly and is enabled! You can do both of these by going to CONTROL PANEL > DEVICE MANAGER.
Scroll down the list till you find DVD/CD-ROM DRIVES.
Right click on the Driver and click properties,you will then be able to varify the two.
3answers
Media player
if it is the only process that freezes up you should re-install your "ripping" software. If the whole computer freezes up you need more ram or need to free up some memory. You may have too much going on when ripping.
Steve Sweetleaf
Steve Sweetleaf
shadow
