Question about Mitsubishi WS-55511 55" Rear Projection Television
MY MITSUBISHU WS 55511 WHEN POWER TURNED ON WILL
MY MITSUBISHU WS 55511 WHEN POWER TURNED ON WILL NOT STAY POWERED UP
Posted by boal1896 on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
I have the same set doing the same thing. I will replace IC and fuses to see if that will fix it.
Posted on Jan 10, 2010
  • Anonymous Jan 10, 2010
    Fuses are good I will look into power supply now
Mitsubishi ws 55511 replace convergance ci and now set wont power up doesnt stay on long enough to get trouble codes
How did you get at the part/s? remove chassis or just the center board? I suspect something happened when you repaired the set.
Does the self check which even if set does not come on, power light comes on for a few seconds and goes off, do the self check (let me know if you need to know how) and see what blink code the power light gives.
Dec 12, 2012 | Mitsubishi WS-55511 55" Rear Projection...
Tip
Mitsubishi WS-55511 Manual Download
Download Mitsubishi WS-55511 HDTV Manual
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Have you misplaced your Mitsubishi WS-55511 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-55511 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
____________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
on Apr 30, 2010 | Televison & Video
Tip
I hope that helps.
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Tv won't stay on
You need to replace one STK393-110 and 2 or more 5amp pico fuses. Very common problem.
Jul 03, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mistubishi WS-55511 won't stay on
23 is a horizontal deflection error could be ho transistor flyback or high voltage splitter
Sep 17, 2009 | Mitsubishi WS-55511 55" Rear Projection...
WS-55511 shuts off with in 1 secound when turned on.
See my reply to your last posting---The set needs The Stk-393-110 and whichever of the two pico fuses is blown replaced--I have instructions AND photos of what the fuses look like.
SD TECH
Sep 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws-55511 does not turn on
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
Sep 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Ws 55511 convergence lines bowed down at bottom of screen
Check resistors might have cold solder joints are changed resistance values around replaced STK393-110
Pay attention to faded colored or fried resistors.
You can download service manual for WS-55511 from HERE to get schematics and technical info. (download all 3 parts of file and use WinRAR to extract file)
Good luck.
Dec 13, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi 55 inch-ws 55511
23 code means "loss of Horizontal Deflection"
Nov 14, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
263 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
