Question about Sony DVP-NC85H Multi-disc DVD Player
DVD player won't read discs
Hello, I have a Sony DVD player model #DVP-NC85H that does not acknowledge any DVD's in any of the five disc slots. I opened the cabinet and observed the operation when the disc changer was opened and closed. I noticed that the disc was not spinning, ie. being read. is there anything I can do or do I need professional help?
Posted by Carlos Thomas on
NOEL
    Top Expert:
  • Sony Master
  • 8,546 Answers
Hi Carlos.
How do you clean a DVD player? CD and DVD players have a laser lens that needs to be cleaned periodically. To maintain your DVD player, occasionally unscrew the player's case, so you can get at the lens to clean it. You need a screwdriver, canned air or a soft brush, a foam swab or camera-lens cleaner, and lens cleaning fluid from a camera store.
How to Maintain Your DVD Player - dummies
www.dummies.com/home-garden/home.../how-to-maintain-your-dvd-player/ Search for: How do you clean a DVD player?
Don't blame your CD or DVD player every time your music or favorite movie starts skipping or refuses to play. The disc may be dirty or scratched. You can purchase a cleaning kit at an electronics store, but rubbing alcohol is a lot cheaper and you can get it at the grocery store or pharmacy. If the problem is dirt or dust, here are some tips for keeping your discs in top condition:
  • When you select a disc to play, the first thing you should do - every single time - is blow dust off, even if you faithfully keep your discs in their sleeves.
  • Next, wipe your discs with a lint-free cloth dampened slightly in rubbing alcohol every time you use them. They not only accumulate dust, but also oily fingerprints that make dust stick.
  • Put your fingers only on the edge and through the center hole.
And if your favorite disc is scratched, before throwing it out, try polishing it to remove the scratch. Disc repair kits are sold at electronics stores and some video stores.
Posted on Nov 26, 2017
5 Related Answers
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: Sony DVP-NC675P Multi-disc DVD player will not play dvd's
have you tried cleaning the laser at all?
Posted on Apr 05, 2008
Jesse Garza
  • 80 Answers
SOURCE: Sony DVP-NC85H Multi-disc DVD Tray locked
Look on the bottom of the unit. There is a hole with the letters ex and op. Shine a light in the hole and you will see a white plastic object with a slot for a slot screwdriver. You can turn this either way but be careful. If you feel resistance and the object does not turn, turn the other direction and the unit will open. Remember if the disc loaded the clamping of the disc is in place so you must turn it the proper way to let the current disc loose hence the op and the ex. Op is open. Ex is exchange.
JC
Posted on Jul 27, 2008
blakerwilson
Blake Wilson
SOURCE: SONY DVP- NC85H
I am getting this error too and I believe it means that somehow the tray that the discs ride on is jammed. I think if you unscrew the three screws on the back and the two on the sides you can pop the top off and see the tray. I bet there is a disc somewhere that didn't fall back into its right spot and it will give you that error... I just opened mine up and sure enough there was a DVD that was in the way... I removed that disc and the error went away. I hope that helps you out as well.
Posted on Oct 02, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
Posted on Nov 19, 2008
Anonymous
SOURCE: Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Posted on Aug 20, 2009
What format of video file can the DVP-NC85H read?
AVI maybe ok. Is there anything error with your converting? I ofen use kigo video converter free to convert video. It's a free ware but works well for me.
Mar 11, 2013 | Sony DVP-NC85H Multi-disc DVD Player
Has anyone ever solved the 'locked' tray problem on a Sony DVP NC85H?
Look on the bottom of the unit. There is a hole with the letters ex and op. Shine a light in the hole and you will see a white plastic object with a slot for a slot screwdriver. You can turn this either way but be careful. If you feel resistance and the object does not turn, turn the other direction and the unit will open. Op is open. Ex is exchange.
Another less elegant way is to open the unit's case, take off top cover and get your discs being held inside the unit that way. Be careful.
Of course you could take the unit in for service but may not be worth the cost.
Mar 13, 2011 | Sony DVP-NC85H Multi-disc DVD Player
My dvd drive is not take any disk but it is opened and close & its read light is blink & a sound is heard why
SONY EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Sony DVP-NC85H Multi-disc DVD Player
Cant turn my prgressive scan off so cnt watch or use sony dvd player
Put dvd player in standby mode and press 3,6,9 buttons on dvd remote to turn off progressive scan off. Let me know exact model number of your dvd player if above solution does not work.
Jun 15, 2009 | Sony DVP-NC85H Multi-disc DVD Player
Won't load discs
laser is bad. usually not economical to fix. laser is around 90% of what you paid for unit. new 5 disc sonys are 129
Jun 03, 2009 | Sony DVP-NC85H Multi-disc DVD Player
DVP-NC85H - - Shuffle play among several CDs
You should refer to your Product's Operation Manual for help on this. Also, you may goto www.sony.com for more info.
Apr 29, 2008 | Sony DVP-NC85H Multi-disc DVD Player
SONY DVP- NC85H
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
JC
Nov 23, 2007 | Sony DVP-NC85H Multi-disc DVD Player
Sony DVP-NC85H Multi-disc DVD Player Logo
142 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
