Question about RTO Esab Power Cut 1250 Plasma W/Pt 32EH Torch 0558001933
It does not work it just flashes the fault bulb and keep blowing air but does not star anything (not the electric arc not even the fan)
Posted by samuellr on
ren1221
  • 194 Answers
When mine act like that I check the tip make sure the air pressure is right and that it has a good ground
Posted on Feb 10, 2010
6amp rear light fuse keeps blowing. Rear nearside tail lamp goes out after a few minutes with a new fuse installed.
Probably the lamp plug is corroded. Pull the bulb and look for white to greenish color. If it is black where the bulb makes contact, it is arcing. Try and bend the tabs closer together.
Sep 14, 2016 | Cars & Trucks
Suburban overheating and air conditioner blowing hot
If you have a viscous fan hub have it replaced as it is not working. The problem you have is that the engine is not driving the fan to draw air through the radiator when idling so the engine overheats . When moving the air flow from driving cools the radiator and so the temp goes back down. If you have electric fans have the codes read to find the fault or check why the electric fans are not working.
Jun 17, 2013 | Chevrolet Cars & Trucks
Keeps blowing bulbs. Last one lasted 17 days
check the ballast leads which enter the rear of the lamp compartmnent they can tend to get pushed in slightly and prevent a good connection to the lamp. If the connections all look good then the lamp driver (ballast) is most likely defective
Mar 11, 2012 | Mitsubishi WD-65733 65" HDTV
SANYO PRO xtrax MULTIVERSE PROJECTOR
Likely the projector has seem some hours on it before being sold second hand to you. A worn out metal arc lamp will wink out like this when it is at END OF LIFE. As the lamp operates, pressures build from high voltage arc current passing through the pressurized bulb. More and more voltage is required to keep the arc struck and operating as temperature rises. As the bulb ages, it requires more power to maintain the arc in the glass envelope bulb. It can rise to a point where it overruns the ability for the power supply in the projector to safely maintain the arc and it winks off, only the fan is left running. When the unit cools, the arc re-strikes and illuminates the lamp.
In short - replace the bulb, but buy TWO of them. One to fix the projector, the other as a spare on hand while awaiting another replacement bulb down the road. These metal-arc lamps typically run anywhere from 50 to 100 hours depending on power supply design and cooling ability of the projector as a whole.
May 10, 2010 | Sanyo PLC XU35 Multimedia Projector
Twin Star electric fireplace fan (maybe heater) doesn't work!
I have a twin star electric fireplace insert model #28efo24grs that is missing a remote any suggestions >>>>917-747-4893
Dec 13, 2009 | Kitchen Appliances - Others
Heater not working when on Heat but working when on Fan
is there a venting fan, that may be faulty not sending power to heat
Aug 03, 2009 | Heating & Cooling
Arc fault breaker trips sporadically
Are there any heaters anywhere in the circuit for this breaker? (ie: bathroom fan w/light and heater) If yes, I would suspect and inspect them first. Also,any type breaker will trip more easily if the electrical connection screws on the breaker are not tight enough...check to make sure that's not the case.
Jul 31, 2009 | Eaton 20A ARC FAULT BREAKER
SONY XBR1 SXRD
I get the same problem (4 flashing red lights).
I done some internet troubleshooting and narrowed it down to an overheated power circuit card/fan issue.
It turns out one of the fans is failing and will not rotate at the appropriate speed to cool the power circuit card, this will kick out the 4 flashing lights from the diagnostics.
In lieu of replacing the fans I have a temporary solution:
For my TV (kdsr50xbr1) the fan in question is located on the far left side (facing the rear). You will see a grill on the back of the TV showing you where the fan is located.
First, get a can of compressed air and blow it into every fan. This will clear away a lot of dust and help the fans move easier.
There is one blower type fan located inside the TV, remove the back panel and look for a tall yellow circuit card just to the left off the center of the TV. Behind that card is a blower (stands upright looks like a tube). Blow air into that blower, you will see a lot of dust come through the duct and out where the large fan in the center is located.
Put everything back together. and provided the fans aren't too far gone the TV should be working again.
Also, if the issue comes back, try this:
When you turn on the TV, shoot a short squirt of compressed air into the fan (Far left facing the rear). This will give it a kick start and bring it up to speed.
It is important to note that the compressed air cans do contain a liquid and as such are not compatible with electronics when they are plugged in. Try your hardest to keep the can upright and not allow the liquid to squirt out where it shouldn't. If it does it will evaporate in a few seconds.
Ok, relatively long post, to summarize:
1. Open back of TV, blow compressed air into every fan to clean them.
2. Blow air into whichever fan is causing problem if it happens again.
3. Keep the can upright if the TV is still plugged in. Don't sue me if you fry your TV.
4. If this doesn't work (has for me) replace fans
Mar 18, 2008 | Sony KDSR50XBR1 50" Projection HDTV
RTO Esab Power Cut 1250 Plasma W/Pt 32EH Torch 0558001933 Logo
345 people viewed this question
Top RTO Welding Tools Experts
Bill Boyd
ray gallant
Are you a RTO Welding Tool Expert? Answer questions, earn points and help others
