I need to program my Access 3 one for all remote with a 32 "Sylvania TV (model SST 4322) . Please tell me the code for this. Thanks!
SOURCE: cant program my universal remote
Search the model # of the REMOTE on www.google.com and a good portion of the manufactures have the Codes on thier sites for you.
SOURCE: 32 inch sylvania tv
This problem is caused by your TV's V-chip setting.
To fix the problem:
Push the "Menu" button (on either the remote or the TV's fromt panel).
Use the "Channel Down" button to go to "V-CHIP SETUP"
Use the "Volume Up" button to select it.
In the V-chip setup screen, the rating that is selected by the user as viewable will allow that rating and only lower ratings to be viewed on that TV. (If TV-G) is selected, then any programs rated higher than TV-G will be blocked.
So, the easistway to get rid of any blocking is to set the rating to TV-MA (mature), and then any and all programs will be viewable on that set. Select "TV-MA" by hitting the "Volume Up" button after you have scrolled down to that rating with the "Channel Down" button.
Then hit "Menu" to exit out of the settings and saave your changes.
SOURCE: Need 3-digit TV remote code--Sylvania 15" LCD HDTV
many of the dish remotes have a "scan" option. This is what the installers use. You'll ned to read the manual. Its a one page explanation.
SOURCE: Need remote code for Sylvania 32" LC320SS9 for Dish controller
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Let me know how it goes and please rate this solution
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
