Question about EuroTech Washing Machines
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it. A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.
Posted on Jan 05, 2010
Wpre6150kwt GE
Un plug the machine from the wall socket.
Remove the front cover by pushing against and releasing spring clips
with flat bladed instrument
Remove front cover.
Unplug and reattach each wiring connection to the motor
and the pump. The connections can be loose and faulty from all teh
vibrations created during the spin cycle. Plug the machine
back into a power source and try the spin cycle.
It worked for me.
Posted on Jul 28, 2011
Apr 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Nov 06, 2009 | Whirlpool LHW0050PQ Front Load Washer
Oct 10, 2009 | Frigidaire Hardware & Accessories
Jun 01, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Apr 05, 2009 | GE Washing Machines
Mar 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Feb 11, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Oct 22, 2008 | Samsung WF337AA Front Load Washer
Apr 26, 2008 | Fisher Paykel EcoSmart GWL15
Jul 17, 2007 | Whirlpool GSC9455 Top Load Washer
582 people viewed this question
