Question about Jabra BT135 Bluetooth Headset
How do i know when my jabra bt135 headset is fully charged?
Posted by luellatrackc on
TO Lady
  • 638 Answers
The blue light should go out.
Posted on Jan 08, 2010
Dalibor Vik
    New Friend:
My jabra BT135 do not light while charging its broken ?
Posted on May 20, 2013
1 Related Answer
Anonymous
  • 9 Answers
SOURCE: Jabra BT135
Firs turn it off then..........
then hold the button for 10 seconds
it will now pair with your phone
the code is "0000"
Posted on Apr 22, 2009
My phone asks for headset in "discoverable mode" How do I get it there?
What kind of phone do you have? I have heard people with LG phones say that it does not pair with their phone. If this is not an issue with you then these steps may be more helpful:
1. Charge your Jabra BT135 until the solid blue LED turns off
(approximately 2 hours)
2. Make sure the Jabra BT135 is switched off
3. To put the Jabra BT135 in pairing mode, press and hold the multifunction
button until the LED stops flashing and turns solid blue
4. Set your mobile phone to "discover" the Jabra BT135 (see your phone
user guide)
5. Press Yes or OK when asked if you want to pair the phone with the
Jabra BT135
6. Enter passkey or PIN = 0000 (4 zeros), then press Yes or OK
7. Your phone will confirm when pairing is complete and your headset
will flash
Jun 17, 2011 | Jabra BT135 Bluetooth Headset
I lost the charger for the jabra bt135 bluetooth headset...where can i buy a new one?
Hey there sanjeev! There should be an USB port on the back of the headset, it is the micro-usb port. Therefore, if you have a cable from your camera, mp3 player or any other gadget that uses a micro-usb port, take their cable, plug it into the headset and let it charge! :D
I hope it helped! Take care! :)
Mar 04, 2011 | Jabra BT135 Bluetooth Headset
I need to find a pass code for a jabra BT135 bluetooth headset
0000
/ Pls come back and let us know if this solved your problem.
Dec 26, 2009 | Jabra BT135 Bluetooth Headset
Lost my jabra bt135 passcode. how can i get one
Passcode for all jabra bluetooth headsets is 0000.
Please get in touch if you need any further assistance on this
regards
Sandeep
Oct 26, 2009 | Jabra BT135 Bluetooth Headset
Trying to connect Jabra BT135 Bluetooth Headset to Blackberry Curve 8900
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Oct 13, 2009 | Jabra BT135 Bluetooth Headset
Jabra BT135
the code is "0000"
Apr 25, 2008 | Jabra Bluetooth Headset with Adjustable...
Pairing Jabra BT135 with motorola L2
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
Feb 11, 2008 | Motorola Mobility L2 Cellular Phone
Jabra BT135 Bluetooth Headset Logo
312 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Mosaub Al Masri
Mosaub Al Masri
Ekse
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
