Question about Whirlpool Duet GHW9150P Front Load Washer
Wont spin, spins only if you tilt machine - Whirlpool Duet GHW9150P Front Load Washer
Posted by sheryandstev on
Anonymous
    Sergeant:
  • 249 Answers
Sounds like you have a loose belt
Posted on Jan 05, 2010
Overloaded the kenmore 70 series washer and it stopped spinning. It still drains the water and fills up with water but it wont spin. It just makes a noise.
More then likely the coupling between the motor and the transmission. To get to it tilt control panel back (held down by either two screws font or rear in the end caps or two clips under front of end caps . Remove two clips holding back to case . Remove plug to lid switch . Tilt case up and forward from back and remove. clips hog pump to motor. Clips hold motor to trani.(screws to hold clips).Coupling in three pieces
Nov 18, 2010 | Kenmore 22422 Top Load Washer
Ficher and pykel top loader smart drive 9 model mw059nz - won't spin or drain but have emptied by hand tilted back and check for all blockages, coild it be the spin motor?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a roper rtw4340sqo when it gets to the spin
Hiya,
if it was not spinning & then started again after you tilted it & set it back down i would suspect maybe a foregn object of some sort was stopping it & by tilting the machine you have dislodged it from where ever it was trapped most common cause is a coin or could be a loose screw dropped out from somewere.. you could check the filters if you have any to see if it has worked its way there if not i would leave it till it happens again then see if you can locate anything.. often tilting the machine will dislodge any objects making them fall to the bottom & preventing them causing the same problem again..
Hope this helps
Apr 22, 2010 | Roper RAX4233PQ Top Load Washer
Very loud shaking during spin cycle
assuming it is a front loader. Check if transport bolts are not still attatched. If not, open back cover and look for shocks for breakage or being siszed. Do you have a noise from the drum while spinning and having no load. If so, the bearings need to be replaced.
Sep 16, 2009 | Maytag MAH8700A Front Load Washer
My admiral washer wont spin the clothes dry
Probably not getting upto full spin speed, drum may wobble more than usual?
Change the motor drive belt below the machine, tilt the machine 45 degree backwards to access underneath, belt pulls off and replace same way.
Jun 09, 2009 | Admiral AW22 Top Load Washer
My tricity bendix tb 1000w started failing to spin the clothes after washing (but would spin when put on the spin only cycle for a while but now wont spin at all) it does not drain the water either now any...
Hi Richie. Your machine (in fact any machine) won't spin if theres water inside the drum (the pressure switch makes it impossible). Sounds like you have a blockage on the waste pump. If there's a filter at the fron, get as much water as possible out the machine, get a few towels and then open the filter. If there's no filter, pull the machine out, tilt it on its back a look for the waste pump (the part that links to the waste hose). Clear any blockage.
If after you removed stuff out of the waste pump, if it still not spinning, then it will be the motor brushes. Remove one and check for wear (if its below 1cm then they need changing, they are normally 5 to 6 cm long).
Cheers
Feb 19, 2009 | Washing Machines
Why wont my washer spin?
You need to replace the drive coupler. It is the piece that is between the motor and the transmission. You can see this part when you tilt the washer back and lay under it and look between the motor and the tranny. This is a very cheap part only about 25 bucks.
Jan 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Wont drain, wont empty, wont go onto rinse, drain or spin during
The filter on this machine is behind the flat at bottom right of machine. Tilt machine back before unscrewing to avoid spillage. If filter is clear get back to me and will explore other possibilities.
Nov 16, 2008 | Washing Machines
The wife needs her washer fixed !!
First tilt this machine back and examine the belt assembly and then start the timer at spin and note the action. If you see one pulley **** and try to turn check to see if it is the motor. Then try it with the belt off. If the motor spins free let it for 2 minutes to ensure it is not failing. The worse case is the gearcase has failed and will need professional help.
Nov 02, 2008 | Admiral AAV7000A
Whirlpool front loader washing machine (AWO3361) WONT DRAIN
Remove drain hose from where it connects to the plumbing under the sink/tub. Inspect the spigot. If clogged, clean. If clean, then tilt machine back and remove drum to pump hose from pump. Check hose and also drain pump. Clear any obstructions.
Nov 03, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
50 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
