Question about Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
I deleted all the viewable files and folders on my lexar firefly jumpdrive, but it says that i still have almost all my memory used up. how can I clear it?
Posted by mgotta on
gelven
    Scholar:
    New Friend:
  • 38 Answers
You may have hidden or locked files. If the files are locked, you'll see an icon to unlock them when you open the JumpDrive in Windows Explorer. If the files are hidden, try and show them: Tools-->Folder Options-->View--> Left Click "show hidden files and folders" Good Luck!
Posted on Jan 05, 2010
  • gelven Jan 05, 2010
    You may try and reformat the Jumpdrive if that's an option when you are viewing it under Windows Explorer through the My Computer window.
HOW DO i USE THE 16GB FLASHDRIVE?
Insert the drive into a USB port on your computer. Then it'll become a drive you can see in My Computer. After you see the drive you can copy files to it like any folder on your system. You may even create folders and child-folders on your USB drive to keep things organized.
Jan 03, 2014 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
I have a jumpdrive4usbgb. I want to transfer a file from my desktop pc to my new laptop pc. how do I do this?
insert the jumpdrive in your desktop pc and copy the contents from the pc to the jumpdrive... then insert the jumpdrive into the laptop pc and then copy the contents from the jumpdrive and paste it in your laptop pc at the specified place..
Oct 15, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
Got old toshiba laptop to use as portable graphic runs windows98
Your old Toshiba laptop most likely does not have a firefly port.
The only way to use your firefly device on the Toshibe is to purchase a firefly PCMCIA adapter card and plug it into the Toshiba's PCMCIA slot and install the card driver.
Please click on this link for details and prices for this adapter :-
http://www.firewire-1394.com/cards-firewire-laptop-notebook-cardbus.htm
Jun 14, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
Storage issue LEXAR Firefly 4GB
Empty your "Recycle Bin", to permanently detect some "hidden" files on the JumpDrive.
If necessary, try a "quick-Format" to reformat the drive, deleting all "hidden" files.
Mar 03, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
I dont know how to save a writing piece from the word pad onto the lexar firefly
Open Wordpad, click File-->Save As; type in your desired name for the file and click the pull down arrow near "Save in:". Select the appropriate Drive (G/D,E or whatever) that is your Firefly. Click save. The file should now be saved as a Rich Text Formatted document on your Firefly. You can save it as a Text Document as well under the "Save as type:" option. Good Luck!
Oct 20, 2009 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Hi there, I'm having problems opening the files on Lexar 2GB JumpDrive FireFly it just says not formatted do you want to format? Please help I have precious photos etc. Thanks
If it says that the files are probably gone, sorry. Try using it on a different system, if it says the same thing they are definitely gone. Good luck I hope it works on a different system.
Aug 14, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Ido not know how to use it
Just install the driver to your computer, you can get it from http://www.lexar.com/drivers/index.html. Installation procedure can can found from http://www.lexar.com/drivers/instruct_win.html. After that, you now use you USB memory card.
Regards,
Jeep Brainy
Aug 12, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Please show me step by step on using the Lexar 2GB JumpDrive FireFly flash drive. I have an HP computer. I need to back up many photos. I will buy more of the same flash drives if I learn how to use them....
What operating system are you using? Should work with XP and Vista. Go to windows explorer and click on C drive, click photos folder, select required photo, click and drag icon to the Firefly icon and release mouse button. File should be copied to jump drive.
Feb 18, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Lexar firefly 1GB Jump Drive - Can't copy files to jump drive
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format pendrive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Dec 28, 2008 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Lexar FireFly 1GB USB 2.0 JumpDrive - Blue Logo
327 people viewed this question
Top Lexar Electronics - Others Experts
Ekse
John Waters
John Waters
Damon Nesselrodt
Damon Nesselrodt
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
