Question about Dell PowerEdge 2600 Server
Connect ide or sata drives to a dell poweredge 2600 for additional storage
Posted by jasontr on
Anonymous
    New Friend:
  • 12 Answers
Yes and No..
The standard machine only allows SCSI, (no IDE or SATA or SAS connectors...
However SCSI drives are not cheap.. so
To overcome the power issue (you will notice there are no 4 pin molex connectors, or sata power connectors). However there is a 4 pin molex socket on the SCSI backplane. You can use one of those molex adaptor cables (one connector to many) to get power, from the molex you can use a 4 pin to SATA power connector.
Next step is to decide the drive you want to use. I personally use SCSI, SATA, SAS and IDE in mine (overkill I know).
Cheapness says use IDE or SATA. You can get a pci IDE/SATA controller card on ebay dirt cheap (PCI cards are compatible with the large PCIX slots), they dont take the entire "socket" up but they work (be carefull here, there is one 5v pci socket on these machines, and 6 pcix sockets, the pcix sockets will accept 3.3v pci cards (look at the notches).
Next you have to mount them, with a bit of jiggery pokery you can feed the IDE/SATA cables past the SCSI backplane into the hot swap bay. (If you dont have any empty caddy's pick them up off ebay), just remember you cant just pull em out like you can with the SCSI's!) - or use one of the 5 1/2 media bays.
Plud the other ends into the appropriate controller card (as installed in the PCI bus).
Load up the OS, install drivers (if needed - these should come with the pci card(s), use the disk manager to initialise/first format the drives etc.
All done.
I have done this myself running a 2600, with 2X U320 72gb SCSI (on Raid) 1 x IDE CD/DVDRW in Media bay, DAT 27 SCSI (channel B) in the second media bay. 2x 146gb SAS on a DELL SAS pcix card (in 2 of the hot swap bays) and an old 160gb IDE HDD (Funilly enough theres a bit towards the back of the two fans on the SCSI backplane that if you press the 3 1/2 drive against seems to fit perfectly in this place and stay there! (I think thats fluke to be honest).
All done :)
Posted on Sep 09, 2010
Anonymous
    New Friend:
  • 60 Answers
This machine will not support SATA or SAS and does not have an IDE slot. It is designed to take SCSI exclusively.
Posted on Apr 08, 2010
Anonymous
    Scholar:
  • 42 Answers
If this machine is able to do SATA, I suggest using it as SATA performs much better then IDE. Many SATA drives are specifically designed to be used in servers and RAID arrays utilizing server specific features such as TLER and RAFF.
SATA is also the current standard for drives and will continue to be for the foreseeable future. IDE is the old standard dating back to the 1980's and is quickly on the way out.
May I suggest Western Digital had drives as I have personally built and deployed 1000's of desktop PC, Small Business oriented servers and all of my personal & business equipment with Western Digital hard drives.
Posted on Feb 06, 2010
Unable to make SATA dive as primary master .
Remove the IDE hard drive, and connect the SATA drive to SATA0 (zero) port. Install the OS on SATA drive. You may have to check BIOS. F2 on boot should get you there.
Oct 09, 2012 | Dell Precision Computers & Internet
I want to install windos 2003 server on dell poweredge 2600 but the server is very slow i want help
I am not sure what you mean by "slow" so I will anwer in general terms. I would recommend 1st that you make sure the PowerEdge meets the recommended hardware specs for Windows Swerver 2003. (Memory, CPU speed, Hard drive capacity, etc.) 2nd- I would run two Xeon processors instead of one and add as much memory as you can put in your system.
I run MS Server 2003 on one of my servers and here is the configuration that I am using:
2 Xeon 2.8GHz processors
6GB ECC Memory
120GB hard drive for the server operating system (Nothing else is on this drive)
750GB hard drive for all other applications
External NAS storage for files, data, etc. (connected to my netword via Ethernet 5e)
With this setup, my server has been running very well for 6 years now. I do maintanance every week on it to keep it up to par. (Simple dusting, checking cables, etc.)
Good Luck.
C2Solutions
Sep 11, 2011 | Dell PowerEdge 2600 Server
Can I install Windows home sever 2003 on a dell poweredge 2600
I would say yes so long as your server meets theses requirements
Minimum system requirements The following minimum specs are needed:[24]
Additionally, the following are required for installation of the operating system only:
Apr 16, 2010 | Dell PowerEdge 2600 Server
Drive Options with a Dell Poweredge 2600
I would definitively not recommend to remove the backplates, unless you want to ask for serious trouble with your system.
I would install a PCI SATA adapter card (one like these) and connect your SATA drives to it.
May 27, 2009 | Dell PowerEdge 2600 Server
I need to add more hard drives to my poweredge 2600
You'll probably need to get caddies for the drives. You can get them from Dell by plugging in your service tag at http://support.dell.com.
Jan 12, 2009 | Dell PowerEdge 2600 Server
Hello sir, I got Power Edge 2600 used not new from a friend, It works fine but its hard drive is damaged. so I was wondering if i can install SATA drives with 7200 rpm to the system? and if so, will it...
This system does not support SATA, personally I would get a 10000 or 15000 rpm SCSI drive.
If really want to use SATA, you can get a SATA controller that plugs into one of the PCI slots. You can probably pick up one for under $50.
Jan 03, 2009 | Dell PowerEdge 2600 Server
Adding DVD to Poweredge 2600
PE2600 has lots of spare power (unless you are already using all 6 SCSI drive bays) ..
You can fit 3 x SATA drives in the space where the (useless) tape backup unit is sitting [you can even buy a 'proper' enclosure = Icy Dock MB453SPF or I think the SNT-2131 will fit ] .. and you can split the power off the Tape drive (4pin) power socket ..
I've not found a DVD burner (only a combined DVD reader / CD burner = TS-L462C) .. however if you have a spare IDE port you should be able to use an external unit [you will need an e-ide cable & enclosure for the drive]
Dec 11, 2008 | Dell PowerEdge 2600 Server
Can i add 142GB of hard disk on Dell PE 2600 motherboard
You can always add more storage to a server, as long as you have enough internal connectors in the server. You can also purchase another scsi or sata backplane to add more ports if you're out of internal connectors.
You may also want to look into a SAN or NAS device to offload some of your not too frequently used data. Many SAN devices give incredible performance with pretty good scalability.
Steven
Sep 16, 2008 | Dell PowerEdge 2600 Server
CDROM and with a bootable CD is not been detected
Same solution as posted before if you need to boot from a DVD: take a Dell laptop CD/DVD combo drive, remove the screws and all and exchange the PowerVault CD drive unit with it. Same internal connector. Can't remember what model I stuck in, but I had to keep the front panel of the drive since it was slightly different, I probably could have glued it, but.... That's a server machine no one is ever going to see but me! :)
That also gave me a CD-Burner which is a decent addition in case you need to quickly burn a CD/make a backup/boot disk (like a "ultimate Windows CD" boot to fix anything that could go wrong).
Nov 29, 2007 | Dell PowerEdge 2600 Server
Dell PowerEdge 2600 Server Logo
1,941 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
