Question about GE Washing Machines
Ge hydro heater washing machine rocks wildly when
Ge hydro heater washing machine rocks wildly out of position when spinning. Have others had this problem? what can I do? GE says you have to have 16 lbs of clothes in it.
Posted by lewiehartley on
Anonymous
    New Friend:
My hydro heater is not wor4kin correctly its not spin/draining or washing properly
Posted on Dec 05, 2010
GE WASHER BELT TOP \DSR LOAD WHDSR316G1WW
put the belt on the motor pulley then start with the other end on the drum pulley and turn it with your hand , i hope this makes sense . the object is to let the pulley do the work of stretching the belt into position
Feb 24, 2013 | GE Washing Machines
Major humpng in spin cycle GE front load madel WPXH214AOWW
Hi from retired Englishman in SW France @ 20:46 Thur evening.
All washing machines, whether front or top loaders, must have all of their feet firmly on the floor to operate without rocking n' rolling and being unstable!
With the machine NOT running push one front corner firmly diagonally (tawards the centre) and if it moves it is THAT foot which requires adjusting downwards until it is really firmly- almost pushing- on the floor. If not that corner do the same with the other. Once the machine is REALLY stable ensure that the locking nuts lock the feet in position so that they will not unscrew and make the machine unstable yet again. Might take a little time but it is imperative, not only for good operation but it also saves damage to the drum supporting mechanism.
John C
Feb 03, 2011 | GE WSXH208A Front Load Washer
Rocks while in spin cycle
Hi, I believe the cause of your washing machine's "rocking" problem is the result of the machine not being properly balanced (on all four legs). Let me explain. On the bottom of your washer and dryer, are four "adjustable" legs. These legs screw up or screw down. If you adjust these four legs so that the washer is perfectly square with your floor, your rocking problem will go away. This should do the trick. Good Luck!
Jan 10, 2011 | GE WSXH208A Front Load Washer
It doesn't self balance and spin out all the water from clothes. the clothes are very wet, especially jeans. And the washer rocks bad during the spin cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 20, 2010 | GE WSXH208A Front Load Washer
Maytag Neptune tl- about 6 years old. Wont finish out the final spin cycle on any setting and also sounds like tub/drum is hitting against side of machine. It also rocks like crazy. Shows the code for...
You have a Clutch malfunction common problem with the FAV6800A and FAV9800A TL's. Owners very seldom report all the conditions of wild tub swings. You are on the ball with info feedback.
See if this post Clutch Fix will get you started.
Post back if you have questions or need help.........Rich
Jul 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I own a ge hydro washer. It won't spin or agitate
If you hear the motor go through the stages, but nothing is happening in the tub, the motor belt may be broken or off.
Aug 31, 2009 | Washing Machines
My ge hydro wash washer model WHDSR316G1WW will not spin or agitate. It did this same thing a couple of months after I bouht it, the serviceman said the belt was off. I've checked the belt and it seems to...
for model: WHDSR316G1WW General Electric Washing Machine
Unplug the machine at least 30 seconds
Turn the dial to the spin cycle, but do NOT pull it out yet.
Plug the machine back in and then lift and close the lid 11 times within 15 seconds and finally pull the knob to start the washer on spin cycle.
This should clear the error code.
GE service 1-800-626-2000 (option 3)
Apr 23, 2009 | GE Washing Machines
Program knob on GE washing machine not functioning
Older washing machines had a 2 position knob push or pull to set and the other position to run, also if the timer is bad it can be replaced the parts are still available on the Internet.
Have a good day...
Tim
Mar 26, 2009 | General Electric Washing Machine Chrome...
NOISE and TUB IS WILD WHILE SPINNING
Is this a new occurence or has it been that way all along? What type of floor is your machine installed on? A soft floor such as pergo or soft shiny lino can cause the washer to be a wild monster when it spins. We placed a commercial type rug with a thick rubber back completely under our washer and that seems to hold it in place perfectly. I received this advice after a service call.
If it has not been happening all along, it could be that you have a problem with the machine being unlevel or that you do have a problem with the tub. Does the tub actually seem loose if you turn it with your hand when empty? Extra heavy loads will contribute to a wild spin as well, and loads that are mixed items. (such as towels with cotton shirts.) it is better to wash the same with each other and not too full.
Good luck to you and thank you for using Fixya! if you have anymore questions or comments, please feel free to get back to me.
Aug 21, 2008 | GE WPXH214A Front Load Washer
Washing Machines Logo
627 people viewed this question
Top GE Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Mike
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
