Question about Samsung WEP500 Wireless Headset
Wont pair no passcode
Won't pair no passcode
Posted by mulitidragoo on
J. Van
    President:
  • 1,738 Answers
The passcode is 0000 (four zeros)
Here's the link to the user manual:
https://techtrain.samsungwireless.com/tekweb/Misc/Main/Accessories/WEP500_ug.pdf
If you found this information helpful, please give ma a big thumbs up when you rate my answer. Thanks!
Posted on Feb 06, 2010
When i pair my motorola S9 it won't pair is there any chance to reset the passcode?
Hey Michael. Are the s9s already paired with another device? If so.... You might want to try turning off both the s9 and the device that's already paired. Then try repairing new device with s9s. Good luck.
Sep 22, 2012 | Motorola Mobility S9 Headphones
Dont know how to find passcode for phone to pair device when using bluetooth
Usually the code is something simple like 0000, 5555, or 1234. Another way is to check your phone's manual, or google your phone name + bluetooth code.
Mar 15, 2011 | Cell Phones
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    Aug 04, 2010 | Apple iPhone Smartphone
    I am trying to pair my lg Xenon with my Lenovo laptop. Both devices ask for the passcode.. I don't know the passcode is what should I enter?
    For initial pairing, you're the one to provide a passcode. So if the system asks you to enter passcode, you will need to enter a code that you will use as this is the enrollment process. Once the passcode went through, the paired devices will be connected and locked to the system unless deleted or removed manually, so make sure to use a generic passcode that you can easily remember so you won't have any problems in the future. Hope this helps!
    May 19, 2010 | Trendware TRENDnet TBW-101UB Bluetooth...
    What is the passcode of nokia n95 8gb? When i transfer a song from nokia6300 to nokia n95 8gb through bluetooth it is not working, in n95 8gb it is asking the passcode of nokia 6300? How to solve this...
    type the pascode that you typed in 6300 for transmit data..if passcode is not given type 12345..it will work....if you want to remove this, you just paired 6300 to your n95. Then it wont ask for passcode..Hope this will help you...Thank you...
    Oct 27, 2009 | Nokia N95 Cellular Phone
    Forgot passcode and i need to pair it with treo
    The default passcode is 0000 or 00000 or 00000000
    Aug 07, 2009 | Motorola Mobility H500 Headset
    My lg 260 wont pair with another lg 260 and it ask for passcodes and it still wont work..
    when asked for passcode enter any code e.g. 12345 and enter thereafter it tries to connect to the other phone. Now the other phone will ask the code where you have to enter the same code, and voila! You"re paired.
    Obviously bluetooth should be 'on' on both the phones.
    Apr 10, 2009 | LG RUMOR Cellular Phone
    My phone is a n95
    What is a t305? It must be a device which can type a passcode. A passcode is a number that Bluetooth devices use to confirm that it is safe to connect. If you pair two mobile phones, it asks for a passcode. You enter it in one and then the same in the other.
    If the t305 is not a device which can enter a passcode, then you need to refer to its manual to see what to do if the phone asks for a passcode.
    Please add details on what a t305 exactly is.
    Feb 05, 2009 | Motorola Mobility Bluetooth Hands-Free...
    How to connect motorola skywing
    Attn!!! Purple light wont stay on long enough to pair.
    DO THIS:press hook button until light remains on solid (mic folded in)fold mic out while light is still solid then pair.
    Dec 08, 2007 | Motorola Mobility H700 Wireless Headset
    Samsung WEP500 Wireless Headset Logo
    134 people viewed this question
    Top Samsung Radio Communications Experts
    Anthony Ward
    Anthony Ward
    Jean Thiebaux
    Muntejaya Ginting
    Muntejaya Ginting
    Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
