Question about Brother DCP-7040 Laser Printer
Toner Life End message on DCP-7040
Getting "Toner Life End" message on DCP-7040. Toner cartridge not low on toner. Tried taping up sensor window, no change.
Posted by Donato on
  • ahmadsyah
    ahmadsyah May 16, 2014
    i have tried it, but doesn't workly, any one have video tutorial for this problem
Craig Gillette
    President:
  • 2,306 Answers
If your cartridge has a lever on the left side near the rear, it needs to be reset, and there's a lever inside on the left that can stick and cause that error. You need to wiggle and pull that lever until it moves freely again.
Posted on Jan 04, 2010
Anonymous
    New Friend:
Any new catridge is fix, but i get this problem is toner life end. what i can do
Posted on Sep 30, 2010
How to reset life toner end message
Easiest way to find out how: go to youtube, search for reset and your printermodel. I found my reset method there.. Good luck.
May 16, 2014 | Brother DCP-7040 Laser Printer
Error message "put the black toner cartridge back in"
I got this same error message on a newly acquired Brother DCP-7040 that I purchased used off of ebay.
As I was troubleshooting this unit (that I bought untested off of ebay - hey gambling has paid off handsomely for me many times before!), this error message kept popping up.
I checked the COUNTERS (page & Drum life) and found out that the DRUM had 0% life left. BUT, the reason it showed ZERO was because this unit did not have any drum! The toner cartridge (TN-360) needs to sit WITHIN the drum (DR-360) on this DCP-7040 unit, as well as in models DCP-7030, MFC-7340, MFC-7345C, and MFC-7440N.
So perhaps some of these "put the black toner cartridge back in" problems could be related to the DRUM (or lack thereof). A possible tipoff (since the toner cartridge actually does slide into the unit much like other units that do not use Brother's DRUM carrier) seems to be the relative ease with which the toner cartridge slides into the DCP-7040 and really doesn't seem to "lock" into position real firmly.
DCP-7040 USER GUIDES: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&type2=-1&prod=dcp7040_us_as&c=us&lang=en&flang=all
Apr 23, 2012 | Brother MFC-7340 All-In-One Laser Printer
Toner life end
You have to reset the toner chip to get rid of the message. Here's a video on how to do it, different Brother printer, but same process: http://www.youtube.com/watch?v=j18yFsjbado
Mar 02, 2011 | Brother DCP-7040 Laser Printer
After installing a new toner I have always the message to install a new one!!!
You have a bad toner cartridge or a poorly remanufactured toner cartridge. This condition called "false toner low". get original one from authorized dealer
good luck,
rate the solution
Nov 27, 2010 | Brother DCP-7040 Laser Printer
Have replaced the drum and toner cartridge and am getting an error message "Toner Life End". We think it may be a problem with a sensor and want to try to reset the machine. Can you tell me how to reset...
Vamos abra a maquina, retira o cartucho, do lado esquerdo tem uma alavanca preta (do lado de dentro da maquina), empurra ela e segura, vai com uma chave de fenda e fecha o sensor de tampa aberta q se localiza do lado esquerdo da parte da frente da maquina, apos vc fechar o sensor a maquina ira fazer o auto teste, e vai mostra Toner erro, coloque o cartucho novamente, delique a maquina fecha a tampa e liga novamente.
Feb 11, 2010 | Brother DCP-8065DN Black and White Copier
How to check the toner level of Brother printer
It has no accurate measure of the toner left, it is reset when you put in a fresh toner and just counts prints. The Brother shines a light thru a little window from right to left and when the toner is empty the light shines thru and it says it's empty.
Jan 13, 2010 | Brother DCP-7040 Laser Printer
Cartridge error msg
Mar 12, 2009 | Office Equipment & Supplies
Dcp 7020 and 7040 toner life end message premature, need override
When the Toner Life End LED flips on, requires you to replace the cartridge, even when there's still toner left in the cartridge. The machine detects end of life by shining a light through from one side to the other.
To circumvent the detection mechanism, remove the cartridge and put a piece of masking tape over or jam a little bit of paper into the clear opening/circle on the right side of the toner cartridge, and then pop the cartridge back in. Eventually, you'll start seeing streaks, and then you'll know that the cartridge is truly empty.
Jan 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Brother dcp 7020 says toner end life
unplug plug it back in, did you remove the protective cover and clean coria wire?
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000065/faq000065_018.html?reg=us&c=us&lang=en&prod=dcp7020_us
Dec 20, 2007 | Brother DCP-7020 All-In-One Laser Printer
Brother DCP-7040 Laser Printer Logo
5,422 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
