Question about Nintendo DS Lite Console
How do you replace a scratched screen on the bottom. My daughter took off the screen protector and now it is scratched and doesn't respond as well.
Posted by nora_schulle on
Anonymous
    New Friend:
Bottom. My daughter took off the screen protector and now it is scratched and doesn't respond as well.
Posted on Jan 04, 2010
2answers
How to remove scratches from iPhone screen?
its not recondmended its a screen /lens not like regular glass where you can buff out fine scratch with toothpaste the following links show how to remove scuffs or very very fine scratches but on some creens trying to remove a scratch may cause malufunctions
I5 Phone Screen Scratch Remover Yahoo Video Search Results http://mashable.com/2014/06/28/phone-screen-scratches/#8C596Bi36aqt How To Clean and Remove Scratches on the iPhone 5 5S 6 6 Plus
Is HTC HD 7 screen scratch proof or I have to use a screen protector .
Nothing is scratch proof, a screen protector is always a good idea, because if it gets scratched,it is easily replaced. An actual screen isn't.
1helpful
2answers
My screen on my mobile phone is scratched quite alot. Can I replace the screen and get a suitable cover to prevent this happening again.
Once the screen is scratched there is no easy or affordable way to replace it...the best thing to do is to install a plastic screen protector as soon as you buy a new phone... they cost a few bucks, but are well worth the price...
Many popular phones have screen protectors made in exactly the right size for the phone...but there also are generic protectors that you can easily cut to fit any phone...
Be very careful and patient when installing the screen protector so that you do not get bubbles under the plastic...have a small piece of plastic or a Popsicle stick handy to smooth out the protector as you install it.
heatman101
3helpful
2answers
I have an LG Versa. I scratched the screen on it.
If you took your phone in to verizon they would tell you you have to have it sent in for repairs as this is a very technical job. Since you used the word scratched and not cracked, you can try to buff the scratch out by purchasing some vehicle scratch remover and working it over the screen with a a cloth and then buffing it with a lint free one. The deeper the scratch the more work it will take, but it is pretty much sanding the screen on a fine level. And you will see results that surprise you.
It may sound awkward but if you do not have a warranty that will cover it then you have nothing to lose but the scratch. Set the phone on a flat surface witch cloth beneath it to prevent scratching the back up, and remove the keypad and put on the plastic backing that covers the battery. You want to use a smooth cloth, not like a sock due to the ruffles in it. Take your time and this works for car stereo screens and even headlights if you have the elbow grease.
If Verizon will not repair it have a go and if anything the scratch will definitely be alot smaller if it is a gash. 3M makes good rubbing compound so try them. Five bucks of a nice screen is worth it and purchase the screen protector as well for future technicalities.
Good luck an Happy holidays.
[email protected]
MY 3 YEAR OLD DAUGHTER HAS JUST SCRATCHED MY SONY BRAVIA TV WITH A MAGNA DOODLE PEN. HOW CAN I GET RID OF THE SCRATCHES?
Clean the surface of the LCD screen with a barely damp cloth.
  • Step 2 Dry the screen with a soft, clean cloth.
  • Step 3 Rub a generous amount of petroleum jelly into the scratch using a cotton swab. The petroleum jelly should fill in the scratch and remain there.
  • Step 4 Immediately wipe the excess petroleum jelly off of the screen with a soft cloth being careful to leave some petroleum jelly inside the scratch to act as a patch or filler.
  • This scratch repair method is effective because of optical density. The optical density of petroleum jelly matches the plastic, LCD screen coating more closely than that of air.
  • To avoid future scratches or gouges, you might consider purchasing a LCD screen protector. These screen protectors are generally made of a thin, plastic film and affix to the screen without adhesives. Not only can they protect against scratches, but they also keep the screen free of dirt, oil and dust while simultaneously reducing glare.
  • When wiping the screen as described Step 4, avoid pressing too hard or you will inadvertently remove the petroleum jelly from inside the scratch.
  • Using petroleum jelly to fill a scratch on your LCD screen could void your screen's warranty. If you are concerned about warranty issues, consult your user's manual for more information.
  • 0helpful
    Scratch in sreen
    By the looks of that picture, it's hard for me to believe that the scratch is not on the outside of the protective plexiglass screen. However, you can remove the protective screen w/o negative effect of the picture. In fact, it will probably reduce the glare from light on the screen. If, in fact, the scratch is still seen w/o the protective screen installed, then it is the lenticular screen that is scratched.
    The lenticular screen is the one with the vertical grooves from top to bottom in it. The fresnal is the back screen that appears to have been lathed in a circular pattern.
    I was txting while laying on the floor and then my phone slid under me and i took it out from under me and the touch screen was scratched can i fix this by myself without having to by replacement parts?
    unfortunatly no.You will have to visit a mobile phone repair shop to have the front glass refitted.For the future buy a plastic thin screen protector that sticks on.ie:iphone screen protector.Hope this helps
    Scratched bottom screen
    If you look on the web, you can find a product that will restore the screen to its origional look by reducing and filling the scratches. Then, get another screen protector.
    1helpful
    2answers
    Scratched screen
    Hello godom, It will depend on how bad is the scratch. For deeper scratches there isn't no fix. For smaller ones there is a specially made scrach fixing paste or something like this, that may be found in some computer stores or electronic/phone service centers. PLEASE NOTE ! Your display is a touchscreen type. The top part of your display - the one you touch, is not made of glass or plastic but a kind of polymer acrilic or similar based materials. Most scrach fixes work and are designed for plastic or glass surfaces. Please instruct or remind this to the person that will attempt the fix. Otherwise it can damage the touchscreen or reduce it's brightness or sharpness. Hope this helps.
    3answers
    Screen Protectors
    When you apply the screen protector, try to flatten it out with a CC as you apply it.
    Nintendo DS Lite Console Logo
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Ekse
    Aron
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
