IF the TV is still playing, you have a vibrating part on the main circuit board close to the or in the horzontal/high voltage section. Like a loose
coil in its housing. If the TV won't come on, then you have something shorted causing the power supply to go into a reduced output mode.
The power supply is overloaded due to a short which is probably in the horizontal circuit. Power supplies oscillate at a high frequency which you normally can't hear. Like 40khz.
