Question about LG LRTN22320 Top Freezer Refrigerator
Lg Fridge/Freezer (Top) GR-S462GC freezing food in Fridge.
Hello My name is ben ,
I have a Lg Fridge/Freezer (Top) Model GR-S462GC. It keeps freezing all the food in the fridge iv had someone look at it and he recomenend i replace the digital control in the back of the fridge .Iv done That & Dident fix the problem .Please help as this is driving me mental ,replacing food every second day
  • Gerry69 Feb 13, 2008
    First of all my fridge department was constantly leaking water I had to dry it out every day, I then raised the temp control but this didnt stop the leakage, and it made everything freeze in the fridge dept, I then lowered the control to as low as it will go, But Iam still getting the same problem with the freezing in fridge dept. Even stuff I have in fridge dept Door is freezing, This as been going on for at least 3 months I cannot see any where in the fridge where the Water is supposed to run out,
  • holland7569 Feb 13, 2008
    i have an indesit fridge freezer and the fridge contents keep freezing even the dial is turned to 0!! Why is this. its has been defrosted and the problem continues
6ya staff
SOURCE:
yeroc
Custom Exchange
  • 397 Answers
SOURCE: lg fridge
heating element seems bad,,sometimes a easy fix
Posted on Jan 20, 2008
Anonymous
  • 210 Answers
SOURCE: i have a lg top freezer, model GR-s462GC
the problem is most likely a thermal fuse, located in the freezer on the evaporator, has blown. The lights on are indicating an error code. If you unplug the unit and then replug it, it will run until it hits the defrost cycle. This will at least keep your food cold until you can get service.
Sgt 48
Posted on Jun 01, 2008
Anonymous
SOURCE: fridge not cold
I have a side by side fredzer and refrigerator digetal thermometer . The freezer temperature will not go below 54 or 53 and the refrigerator states at 43or 45.
Posted on Aug 29, 2008
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: food in bottom drawer of fridge freezes. what is the problem?
Try adjusting the food compartment temp. There are many possible reasons that will cause this. Look for exact model number located inside food compartment bottom door when opened. For example 91.802574 This will give us the exact diagram to work with to help you solve this. Below is a link with Q&A that you also can use to resolve this problem.
Let me Know and Thanks, Sea Breeze
http://www.applianceaid.com/refrigerator.html#freezing
Posted on Feb 01, 2009
Anonymous
  • 19 Answers
SOURCE: Refrigerator LG Model GR-T452G freezer works but
Locate your defrost timer, they are either in the buttom front of the refrigerator, in back of the refrigerator, or inside compartment behind the plastic covers. On the defrost timer there is a slot were it can be turned using a screwdriver, or there is a round window were you can see it running.when you turn this dial and it clicks, you should now go into defrost. with all the ice build up in your evaporator you should hear the ice cracking indicating that the heaters are working, if not you might have open defrost heaters.
Posted on Feb 21, 2009
Lg service support
Hi Linda, check the back wall of the freezer. If it is covered in frost, it's not running it's defrost cycle and the evaporator are insulated in frost, not allowing the refrigerant to do it's job. Probably a bad defrost thermostat or defrost heater. Hope that helps.
Jul 23, 2017 | Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
My LG19320 Top Freezer Refrigerator is freezing all the food in the lower part of the fridge. Any idea what may be the problem?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 05, 2011 | LG LRTN19320 Top Freezer Refrigerator
Fridge keeps freezing food even when set on warm
heatman101
Jan 04, 2011 | LG LRTN22310 Top Freezer Refrigerator
Food in bottom compartment freezing food
you have the air flow regulator in the bottom of the fridge close to bottom compartment wide open experiment by closing it gradually till you have the desired result.
Sep 18, 2009 | GE Hotpoint Top-Freezer Refrigerator
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
LG GR-292R freezer works/fridge does not.
well i have the exact same refrigerator but opposite problem.... the freezer works but the entire refridgerator is a freezer....why is the fridge part freezing everything. This appeared to happen after the power went out and the entire fridge is a freezer now.
Mar 02, 2009 | LG LFD25860
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
LG LRTN22320 Top Freezer Refrigerator Logo
644 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
deecee73
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
