How you pair you headset with your pc
With your headset fully charged, and turned off, press and hold the multi-function button, until the blue and red leds flash alternatively. It is now in paring mode. Now, make your PC bluetooth application (don't know which bluetooth stack it has), search for other devices, Select 'MILOS-9', and, if a PIN (or passkey, or pairing code) is requested on your PC, enter '0000' (four zeros). The blue led will flash three times, indicating successful action. If the pairing procedure fails, turn your headset off, wait for 10 seconds, and start it over. From now on, you will need just to turn the headset (and the PC bluetooth hardware) on. They should automatically connect to each other. If they fail to do so, try to right-click on 'MILOS-9', on your PC's bluetooth device list, and select 'Connect'.
Hope you are able to sort your problems out.
Cheers!
Carlos
