Hi.
There are several ways to change the language settings on the TomTom One.
If you do a reset using the reset hole, after restarting the TomTom, you will get again the initial setup page. Page 8 will ask you which one is your favorite language for using the TT.
Another way to change TT language is using TT menu to change language. You can follow the step by step instructions given on this page. Click here to open the link.
Regards.
SOURCE: Language Barrier
Follow instructions:
http://www.tomtom.com/support/index.php?Language=1&query=language&FID=4532
(Please remeber to rate...)
SOURCE: My Tomtom One XL, shows strange language and I can t change it.
Boot up your tt, tap the map screen, then tap change preferences (bottom far right icon next to the forward arrow), tap the forward arrow until you come to an icon with flags, tap the flags icon. You will then be able to set your language.
Hope this helps
SOURCE: how can i reset my tomtom text to english
Do you want to change the language of the VOICE or the WORDS IN THE SCREEN? These two are independent from each other and need to be set up by separate.
1) To change the VOICE, you need to download an ENGLISH VOICE.
a) Start TomTom Home on your computer.
b) Plug in the TomTom dock to a USB port on your computer and plug in your TomTom GPS on the dock
c) Turn on the GPS and when asked "connect to computer" answer "yes" (you may not be asked if you want to connect; TomTom Home amy detect your GPS and connect to it automatically). If your GPS is not connecting to TomTom Home, turn the GPS off, turn it upside down and press the "reset" button for 7 seconds, place the GPS back on the dock and turn it on. It should automatically connect to TomTom Home now.
d) On the TomTom Home software, click on the icon labeled "Add Traffic, Voice, cameras..."
e) Click on the icon labeled "voices"
f) Click on the icon labeled "computer voices"
g) Click on any of the voices that says "English" on the second ("language") column; download and install the voice
h) Go to the TomTom Home top menu and under "DEVICE" choose "DISCONNECT DEVICE". Wait a few seconds until the GPS communication with the computer is broken and the GPS restarts. You don't need the computer anymore for now
i) On your TomTOm GPS, tap on the middle of the screen to bring the menu.
j) Touch "CHANGE PREFERENCES"
k) Touch "VOICE PREFERENCES"
l) Touch "CHANGE VOICE"
m) Select any of the voices that are in English (such as "SUSAN, English US, Computer"). After this, you can TEST the voice. Check that you can hear the voice, otherwise, you'll need to adjust the volume. We'll do this later. Touch "SELECT" to select the voice. Press "DONE" on the next 3 screens until you're back to the GPS navigation screen
n) To change the volume, tap on the LOWER LEFT rectangle. You'll get a VOLUME SLIDE. Slide it to the RIGHT to increase the volume and to the LEFT to lower it. I keep mine around 85% volume. YOU ARE DONE SETTING UP A NEW VOICE
2) To change the LANGUAGE of the WRITTEN DIRECTIONS on the screen:
a) On your TomTom GPS screen, tap on the middle of the screen to bring the MAIN MENU on
b) Tap on the PREFERENCES icon
c) Tap on the RIGHT ARROW 7 times or until you see an icon labeled "CHANGE LANGUAGE".
d) Using the UO and DOWN arrows on the GPS screen, scroll up or down untill you see the langauges you're looking for. You'll get a screen with several languages available, including "English UK" and "English US"
d) Touch on the screen you want. The screen will automatically go back to the previous menu screen that shows the "CHANGE LANGUAGE" icon. Touch the "DONE" button.
YOU ARE ALL DONE. Now, your VOICE and all WRITTEN DIRECTIONS should be in ENGLISH.
If this didn't work, please report back so that I can provide further assitance
