Question about Sony Playstation 3 (PS3) Console
PS3 60gb one year old and not working, when you switch on goes to green for a few seconds and the off to red.
Posted by jameskinya on
matrix6977
    Problem Solver:
  • 16 Answers
Hold the reset button while the system is off for approximately 5 seconds, you will hear a series of beeps from the system which will indicate a 'formal' reset has been made
a 'master' or 'hard' reset will actually wipe your systems data and restore the system back to factory settings... which will cause you to lose all your save game and profile data...
Posted on Jan 04, 2010
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
Starts to power on,then shuts down
Have you checked the filters? I have a Sanyo PLV-75 and had a similar problem.  The normal fan would come on when the unit was first started, then after a few seconds the secondary fan came on and then the unit would shut down.  Called tech support and they asked if I had cleaned the filters. I did it, and it worked great.  Check the manual for where the filters are and hit them first before getting a new bulb.  Hope it helps!
May 24, 2009 | Sanyo PLC XF10NZ Multimedia Projector
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
PS2
Faulty button, fuse. Try a new power cable, if that doesnt work then it will need a new on/off switch.
May 16, 2008 | Sony PlayStation 2 (PS2) Console
Can't print
It flashes orange for a few seconds, and then back to green, and then back to orange every few seconds. I can't shut it off unless I unplug it. It also makes a horrible racket.
May 08, 2008 | Canon S 750 InkJet Printer
Philips 42PF9945 on/off switch problems
Hi huttleywoof,
I've had the same problem 1 week ago. Bought new wirewound ceramic resistors (5w 6.8 ohms) and replaced the old ones.... It helped to majority of people who had the same problem, but mine has now some other issues with appearing diffrent colors on the screen which are not supposed to be there :) Like all goes blask with few red pixels or green :-) Having fun now and can;t find service manuals for this TV :(
Feb 16, 2008 | Televison & Video
GE 31GT740 clicks off and on
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Reverts to standby from switch on via TV or Video
No 5v rail because FET MTP3055 o/c. (BUZ71 will do nicely)
Goes straight to standby, after a quick burst of power
Replaced R952 (39K), had gone slightly high
Nov 23, 2007 | GE 31GT740 31" TV
Sony Playstation 3 (PS3) Console Logo
174 people viewed this question
Top Sony Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
