Question about DFI nF4-DAGF Motherboard
Dfi nF4 DAGF red in light flashingon MOBO.. Fans
Dfi nF4 DAGF red light flashing on MOBO.. Fans all come on,, but nothing else
Posted by matrat43 on
Anonymous
    New Friend:
  • 4 Answers
The cpu power probably isn't plugged into the mobo. It's the 4 pin spuare pwr connector
Posted on Jan 05, 2010
Manual for LPUTNF4SLIDREXPERT
please help me find an online manual for this motherboard please mate hi brian i was wondering if u cud help me find an online manual for this motherboard (DFI LANPARTY UT nF4 Ultra-D) as im selling it on and want to check all the jumpers are in the correct positions please help me out dude, many thanks in advance for any help matey
I have a DFI LANPARTY UT nF4 Ultra-D and have been been unable to use all of the memory slots. I originally bought 4GB but have only been able to use 2. Is there a setting that i need to enable?
Hi, you can use up to 3 gigabytes on windows xp 32 bit with service pack 3.
You need a 64 bit operating system to use 4 gigabytes of ram.
Here is some info:
CPU
AMD Athlon 64 FX / Athlon 64 / Sempron Socket 939
Chipset
NVIDIA nForce4 Ultra
Front Side Bus
2000MT/s
HyperTransport interface
Memory
Four 184-pin
DDR SDRAM DIMM sockets
Supports dual channel (128-bit wide) memory interface
Supports up to 4GB system memory
Supports
DDR266, DDR333 and DDR400 DDR SDRAM DIMM
BIOS
Award BIOS
CMOS Reloaded
CPU/DRAM
overclocking
CPU/DRAM/Chipset overvoltage
4Mbit flash memory
I want driver for this motherboard
Here are the links for the DFI NF4 driver you have requested.
Blue screen on windows 7 with geforce 210 and 1 GB
May be Your Problem due to corrupt RAM DDR Commonly reason of Blue Screen Problem is Ram Fault.So U can change Ur Ram May B Ur Problem Will Be Solve.
I need to connect wires to DFI LANParty mother board.
You can find your manual here in PDF version, this will allow you to " zoom " in on any connection information your may need.
http://img.lanparty.tw/Upload/Manual/CM/lputnf4%20847505101.pdf
1helpful
2answers
I am searching a site where download the manual for dfi lp ut nf
Not a problem! I have it right here for you.
http://us.dfi.com.tw/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=manualTab&windowstate=normal&mode=view&downloadFlag=true&itemId=479
Scroll down this page a little. There are tabs going across that you will see.
BIOS, Driver, Manual, Technical Doc., ABS Profile, and a tab that has an arrow pointing to the left.
The Manual tab should be highlighted. If not. click on the Manual tab.
Scroll down to the Fourth file listed.
-> Motherboard Manual English/Multilingual Manual <-
Under this heading is -> 87910551.pdf <-
The 87910551.pdf is in Blue. Click on this for the Motherboard Manual.
You have Adobe Reader on your computer. Adobe Reader uses PDF files. I use Adobe Reader 9.1 If your version is not at least Adobe Reader 9, I invite you to go to Adobe.com, and update it. Makes downloading PDF files real S-M-O-O-T-H.
If you do not have your downloads set to go to your My Documents folder, this PDF file will go to your desktop screen.
To look at it, just double-click on the file name.
This same link I gave you has the drivers you requested. Just click on the Drivers tab. Also BIOS updates. As you can see on this Manuals page, the manual for how to use Nvidia RAID is there too.
DFI Infinity NF4 SLI won't start
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
Board stopped working
try one by one first the graphic card then with powersupply
DFI nF4-DAGF Motherboard Logo
Top DFI Computers & Internet Experts
Ekse
Chris May
Chris May
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
