Question about Ariston Technologies Ovens
Got a fan assisted gas oven. Trying to bake a cake
Got an Ariston fan assisted gas oven/electric grill. Trying to bake a cake at 175C however oven temperature flucates and continues to rise to 210C regardless of the control knob setting at 175C. Have had cooker representative visit and all is ok. Had the gas man visit and after putting on a new regulator the problem still persists.
Posted by marcie182 on
ashburton
  • 417 Answers
Temperature control with gas ovens is not an exact science. However the control should be better than you say.
Have you tried reducing the set temperature to compensate for the 'overshoot'. It may be worth a try.
Posted on Jan 04, 2010
I have a parmco ar900leg gas stove with a multi function oven power. Its been cooking a treat for the last six months when we bought it. was installed by a gasfitter and correctly. Now, the bottom...
u say element not working? so its a gas and electric? If so check the element with a multi meter for continuity. I would say check ur gas safety valve also but u say it does work in grill?
Mar 08, 2015 | Ovens
When baking the oven doesn't bake evenly and always bakes quicker than the time on recipes. Items burn and the middle is raw. Can the oven be recalculated to work better?? John
Electric ovens are always different from gas ovens. You have to set the temperature on average 10-15 degrees lower and watch out 15 minutes earlier if you are baking cakes, 5 mins for cookies etc. Always bake in the centre of the oven. use a metal bowl of water in another tray which may help balance out the temperature
Jan 01, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I have an bajaj oven and im trying to bake a cake and everthg i bake it the sides of the cake get baked and the middle portion remains raw..ive tried all the up flame,down flame and also both the up and...
if your oven is gas its is very difficult to make perfect baking of of the uneven heating,if your oven is elecric is with convection that one good compare to gas oven on an electric oven without convection, the advantage of oven the with convection is even heating.
Dec 24, 2010 | Ovens
We just purchased a new ariston oven but there is no grilling tray. Were we supposed to buy the tray separate?
It should have been suplied with a grill tray of some description, go back to who supplied it for you, and ask them for one.
Aug 14, 2010 | Ariston Technologies Ariston FO98P...
Best setting for baking cakes
good day,
hope this link below will solve your problem.
baking.
The best bread machine we've found for gluten-free bread baking. Programmable feature puts you in charge. Bakes a delicious 1.5 to 2 pound loaf every time. It has a viewing window, automatic settings for breads, cakes and jam, sourdough starter and programmable cycle that makes gluten-free bread in under two hours!
Aug 01, 2009 | Smeg SE250XUK Stainless Steel Electric...
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Blodgett Mark V, Sinking Cakes
They can help you here. Great Co.BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Dec 22, 2006 | Blodgett Model Mark V Single Electric Oven
Ovens Logo
331 people viewed this question
Top Ariston Technologies Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
john h
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
