Sharp AR-5316 Advanced Digital Imager Copier Logo
Anonymous Posted on Jan 04, 2010
I am using Sharp AR-5316E copier (It makes noise)
I am using Sharp AR-5316E copier While making copy the machine makes a sound which is not usual, i noticed that this sound comes when the machines colects paper or when it has finished copying the last page.
Your answers are very helpful for me... thanks
  • 2 more comments
  • Anonymous Jan 06, 2010
    it makes a sound like low car racing,
    as (hmmmMMmmmmMMmmmmmMMM)and also sounds like click (tik tik , tik tik..)
    i hope you i have been able explain correctly...
    thanks
  • Anonymous Jan 09, 2010
    dear i have a driver CD that came with my sharp AR5316E but i dont know how to give you... if you know any way tell me i will send u
    Thanks dear i thinks something like this has happend but i dont know where is the toner waste box... i would appreciate if you show me step by step...
    thnkx
  • Anonymous May 11, 2010
    Is it like a loud clicking sound (like a plastic gear skipping over another plastic gear) or more like a low rumbling sound?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
818
Points
Yes, Toner waste sump over filled; 100%!!! To confirm it, remove Toner cart. & make copy; I found same problem in Toshiba eStudio161, which is Sharp AR163, 5015, 5020 & 5316(all are same)
Anonymous
Level 1:
New Friend:
  • Posted on May 09, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
818
Points
Somebody help me, i've got error L6 on my digital copier sharp 5015..any solution for this?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2440
Points
I have a sharp ar 5316 e photocopier but the printer cd is broken shell i give the sharp web adress
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jan 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
2137
Points
12
Could be the toner...but it could also be the scanner unit returning home..when the rail gets dirty it will make that humming sound...clicking can be the spring inside the fuser.
You can disassemble the fuser but it can be kind of a bear to get back together if you have never done it before.
You can clean the scanner rail by removing the left cover with two screws on the glass top, and the large glass will come up. Wipe down the rail and put a very small amount of tri flow lubricant on a rag and wipe over the rail.
As for the driver, I would call the sharp phone number, it should be free.
    You would know if the toner box is the problem if when you opened the front door there was a bunch of toner everywhere in there, if there isn't a pile of it then it isn't the box, it may be the scanner rail or another problem I mentioned, you will probably have to call a local technician.
    We charge 120 an hour...so be prepared for that.
Anonymous
Level 2:
New Friend:
  • Expert 170 Answers
  • Posted on Jan 06, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
170
Questions
0
Helped
47502
Points
280
Check the toner cartridge maybe the waste toner box is full
Anonymous
Level 1:
New Friend:
  • Posted on Jan 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
818
Points
I need a driver software for Printer sharp AR 5316 & I searched in the web I could not found it correctly, will you please help me
There's a black line on copies of SHARP AR-5316E
Cartridge(s) may be putting out too much toner or scratched
8helpful
4answers
1helpful
2answers
My AR-5316E copier is displaying this error code H and 4
Your heater lamp maybe busted.
Use the simulation 14 to cancel the error..
If nothing happens then you need to check your heater lamp.
2helpful
3answers
I have sharp AR-5316E copier, the indicator is
it is the problem your copier fuser unite problem thermostater or heat roller is over temparature . You press # interrupt c inturrupt then 24 press print key 00 then machine is of after on is ok
1helpful
Erorr L1 Apears in the display
L1 IS USUALLY TO DO WITH THE SCANNER POSITION CHECK THAT THE SCANNER LOCK SWITCH HAS NOT ACCIDENTLY MOVED CAUSING A LOCK YOU CAN CHECK THIS BY LIFTING THE LID AND TURN THE MACHINE ON AND OFF IF THE SCANNER IS FREE YOUN WILL SEE IT MOVE TO THE HOME POSITION.
My Sharp AR-5316E has just refused to power on and its a new machine. Please what do I do?
a new machine under warantee should be returned to the supplier, else check to make sure the cable is well plug to a good socket
7helpful
2answers
Sharp AR 5316E
i want a driver for charp ar-5316e
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
