Question about Nerf Toys
Nerf Vulcan won't auto-fire
Nerf Vulcan will shoot manual only, but will not auto-fire
Posted by dacrazylegs1 on
Anonymous
    New Friend:
I had the same problem with two guns out of the box. Turned out that the dividers in the battery tray kept the batteries from touching each other on some brands of batteries. Remove the dividers and should work. You can verify this by measuring the voltage on the two terminals of the battery pack.
Posted on Feb 25, 2010
  • Blake A Roo
    Blake A Roo Nov 08, 2013
    i snaped my handle before putting it on the gun i need help
Praxis pump slide handle jammed
1. Get a ruler
2. Push the ruler down the barrel so the end is near the bottom of the disc
3. Jiggle the ruler from left to right
4. Shoot the gun/Press the disc eject switch
Dec 25, 2011 | Nerf Toys
My shutter won't fire using 18-55 lens, either on Manual, P or Auto mode. It is set to AF. But when lens is set to MF, shutter fires. I tried switching to another lens and shutter is perfectly fine.
I could be that your lens isn't focusing. If the Auto focus can't find something to focus on the shutter won't fire. If you are shooting in low light sometimes it has trouble try shooting something that is well lit. also your auto focus point may be somewhere other than the center. there is a button on the top of your camera that looks like this [ ][ ] [ ] [ ]
More or less that will switch where your focus point is. If you look in the view finder and see a red dot when you push on the shutter button that is your focus point. push the above button until the red dot is in the centre. that may fix your problem.
Jul 26, 2011 | Canon EOS 450D Digital Camera with 18-55...
I have a nerf nite finder that when i **** it back it fires without warning do you have a soulution
That sounds like an internal mechanism issue, parts of the plastic on the inside could have worn down, causing the spring to slip and fire the bullet off.
May 04, 2011 | Nerf Nite Finder
How many and what type of batteries are required for Nerf Dart Tag Strike Fire Two-Pack?
Wow, this is hands on the dumbest question EVER.
You know, no offense or anything...
Look- this is a manually operated toy.
Unless you or I got the name screwed up, or that picture up above is incorrect...
Oh wait, I just looked at it on Amazon.
Two solutions-
1.) READ THE INSTRUCTIONS, THEY'RE THERE FOR A REASON!!!
2.) Pull the cocking slide on top of the gun back, after inserting a bullet. Pull the trigger to fire.
That's all!!!
Oh yeah, 1+1=2, in case you didn't know that either.
LOL just kidding!!!
Good luck (idk why)...
Feb 27, 2011 | Hasbro Nerf Dart Tag Strike Fire Two Pack
HELP!!! My nerf gun maverick is broken.? when i shoot it the bullet fires about 10 feet only. when I took it apart nothhing seems to be wrong. Please help me fix it by telling me what to do.
I had the same problem too. Try opening it up and looking at some online pictures and compare them, if you still cant find the problem and you have the receipt, take the unit back where you got it from. Look at the springs really closely my maverick was broken due to a spring that slid out of its elevated piece of plastic. I fixed it lubricated some parts and put it back to together. It works great now. :)
Dec 21, 2010 | Nerf Maverick Blaster
Our new Nerf Vulcan EBF-25 won't auto fire. We tried changing the batteries to several sets of new ones, but it still won't work. Any thoughts?
You might have a bad motor in your nerf vulcan. If you want the aouto fire to work than you may have to get a new Vulcan.
Dec 13, 2009 | Nerf Secret Strike As 1
Nerf gun wont shoot its cocked and when i pull the trigger nothing happens
the relese mechanism came loose and i put the pin back in if anyone needs help ill be happy to help fix it
Sep 06, 2009 | Hasbro Nerf Dart Tag Strike Fire Two Pack
Toys Logo
2,718 people viewed this question
Top Nerf Toys Experts
Moderator Canada
Moderator Canada
MODERATOR WORLD
Alyssa DeWolfe
Alyssa DeWolfe
Level 1 Expert
Are you a Nerf Toy Expert? Answer questions, earn points and help others
