I replaced the blower for my H400 heater i try to heat the spa i hear 2 clicks, then get the AO error code. i can see the blower turning and feel the air exiting the exhaust but no flame turns on.
Your problem then would be the pick up tubing and/or switch attached to the blower that closes once the blower is on to allow the heater to ignite. Pull the tubing and check it for dust or other debris clogging it and check inside the blower housing for the same. If you can test the switch under operation, you should see it remains open during start up which is why the burners won’t fire. If you do not find any obstruction (if you can, blow some compressed air thru too just to be sure) then you will need to replace the switch.
Ao code blower does not turn on
