1st Does any screen come up? 2nd Does it make noise when it comes on? 3rd Try unpluging the power cord and take the battery out for 2 mins. then let me know the what happens1st Does any screen come up? 2nd Does it make noise when it comes on? 3rd Try unpluging the power cord and take the battery out for 2 mins. then let me know the what happens
You can't post conmments that contain an email address.
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the hp pavilion dv6700 power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
see if you can boot into safe mode
as the pc starts tap F8 - should be presented with a menu - choose "safe mode" from the menu
if that works, then try a system restore to before the problem started
start>programs>accessories>system tools>system restore
choose a date before the problem started
reboot
Hi, believe it or not?; sometimes the current in certain areas of the home or apartment have separate power circuits from the main direct current system. Check to make sure there is electrical current running through your socket, and or light switch to open the circuit. Thanks, paul7of9
This is a dumb question i'm going to ask but is the power cord plugged in. Mine recently killed over. Come to find out it was the battery pack, which was fully charged, just didnt work anymore.
