Question about Kenmore 62602 Electric Dryer
I HAVE A KENMORE 90 SERIES AND THE DOOR KEEPS ON OPENING, SO I TOOK ALL OF THE CLOTHES OUT TO SEE IF THERE WAS TO MUCH IN IT, AND EVEN WITH NO CLOTHES IT OPENS?? IT DOSENT APPEAR ANYTHING IS BLOCKING THE DOOR FROM SHUTTING...
Posted by longojk on
Jeff Meyer
  • 423 Answers
Inspect the door and when you open it, does the latch hold the door closed? If not the dryer door / latch may need to be replaced.
But check the door as it opens... the door hinges may have been damaged, causing the door to not close properly and the latch may not be damaged, only the hinges.
Good Luck!
Posted on Jan 03, 2010
How to fix the door switch
What is the model number of your unit?
Nov 24, 2012 | Kenmore Series 70 80 90 PN281798 Dryer...
My Kennmore Series 90 door keeps popping open so the dryer stops
Could be a defective door latch.
Could be an over-loaded dryer.
If you are not over loading,then replace the door latch.
Cost about 5 bucks.
May 08, 2011 | Kenmore 63942 Dryer
Won't spin or rinse, took clothes out .... too heavy maybe??
you have a bad lid switch,you can by pass it,remove the switch,put the pos.neg. together with wire nut and your finished-mike
May 20, 2009 | Kenmore 23822 Top Load Washer
I have a Kenmore 90 series that i have to run through drying cycle twice before the clothes get dry"
try washing the lint screen it gets blocked if you are using fabric sheets
Apr 28, 2009 | Washing Machines
Kenmore 90 Series Washer
CHANGE THE LID SWITCH
Apr 18, 2009 | Washing Machines
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 series not drying.
remove the ventin from behind the unit you need to replace and or clean your vent !!!!!
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Kenmore electric dryer series 90 model 66904691 will not start. Dryed a load of clothes went to start again will not do anything , checked fuse box, fuse not blown what could be the problem
Check the automatic door shut off switch and wiring. When the door closes it actuates a switch (completes and electrical circuit) which allows the dryer to operate.
Aug 23, 2008 | Kenmore Dryers
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Kenmore 62602 Electric Dryer Logo
195 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Ned Halaweh
Ned Halaweh
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
