Flash is a programming language that many publishers use to create animations, games, and interactive programs for the web. Flash is also used for programs run locally on a users computer. To use these Flash based programs and web applets, the end-user must have Flash Player installed. One component of Flash Player is a file called "flash.ocx." If this file is missing or damaged, you may get an error message.
There seems to be two root causes of this error. A description and solution for each follows:
You receive the error message "Cannot find the file flash.ocx" every time you start your computer or each time you open your web browser (such as Internet Explorer). This is usually the result of a missing "flash.ocx" file caused by an incomplete installation of Flash. Here's how to remedy the problem:
Run the downloaded program and allow it to finish.
Once the uninstall completes, restart your computer.
Visit the Flash Player websiteand download/install the latest Flash Player version.
That's it!
You receive the error message "Cannot find the file flash.ocx" at seemingly random intervals or when starting a specific program (other than your web browser). First, perform steps 1-4 of the previous solution. This will insure you have the latest version of Flash Player installed. If you still receive the error message, continue with the steps below:
Navigate to the folder "C:\WINDOWS\system32\Macromed\Flash\". In this folder you will see a file named "Flash9f.ocx".
Make copy of the "Flash9f.ocx" file in the same folder as the original (copy the original, then paste the copied file into the same folder).
Rename the newly made copy to "Flash.ocx".
If the previous steps don't eradicate the error messages, change your screen saver to one of the defaults that are included with Windows (such as "3D Text").
Hi
first make sure you have the file MSCOMCTL.OCX in your system
if not you can search and download the file copy to system32
then run this command -- regsvr32 mscomctl.ocx
it should solve this problem
Hi, Flash is a programming language that many publishers use to create
installed. One component of Flash Player is a file called “flash.ocx.”
You receive the error message “Cannot find the file flash.ocx”
missing “flash.ocx” file caused by an incomplete installation of Flash.
Here’s how to remedy the problem:
Visit the Flash Player website and download/install the latest Flash Player version.
That’s it!
You receive the error message “Cannot find the file flash.ocx” at
steps below:
Navigate to the folder “C:\WINDOWS\system32\Macromed\Flash\”. In this folder you will see a file named “Flash9f.ocx”.
Make copy of the “Flash9f.ocx” file in the same folder as the
folder).
Rename the newly made copy to “Flash.ocx”.
If the previous steps don’t eradicate the error messages, change
(such as “3D Text”).
What was the error message, also you are stating only problems, not questions, please be more specific into what you want to do so people can help you.
the only solution I can think of for the OCX error is to re-register it
Go to 'Start' -> 'Run', type (or copy/paste from here) 'regsvr32
C:\Windows\System32\MSINET.OCX' and press Enter (a message box normally
appears containing 'DllRegisterServer in C:\Windows\System32\MSINET.OCX
succeeded.')
Also you might have to update your .net frameworks (check microsoft update.
I went to the bridge barron site and only found this
...and this happens when????
