It's possible your graph is set to Polar mode.
to fix, press [mode] (top row, 2nd from the left) and go down to where it says "Func" when you reach func just press enter so that it's the highlighted text. i'm assuming that "POL" is highlighted right now?
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and then select 4:PlotsOff.
If the message appears when you try to graph functions deactivate the
statistical plots. To do so:
Press [2nd][Y=] to access (STAT
PLOTs) Select [4:PlotsOff] then [ENTER]
That should solve your
problem. Post a comment to this thread if you still have trouble
graphing.If the message appears in another context, it sure
would help knowing the context of the error.
Hello, The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen. Hope it helps.
If you are in the stat mode and entering points in list 1 and list 2, it could be that one list is longer than the other.
If you are just trying to graph from the y= screen, one of your plots is probably turned on. The easiest way to fix this is to press the 2nd button the the plus button, then 7 and then 1 and then 2. This will reset to factory settings.
This is probably because you have the stat plot on. You would need to go to y= and then go to the top where it says stat plot 1 and un highlight it if it is highligted. That should fix your problem.
