Samsung HT-X200 Theater System Logo
Posted on Jan 03, 2010
Update for Samsung HT-X200 codecs to support mkv
How to update Samsung HT-X200 codecs to support .mkv format ?
Where to find such a codec ?
2 Related Answers
Anonymous
  • 8619 Answers
  • Posted on Sep 15, 2009
SOURCE: I need to reset the region code on a samsung home
Hi
Thanks for using FixYa. Please follow this procedure to reset the region code (or to make it region free).
Open tray and remove any disks in tray, then Close the tray. 1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM) 2. Reconnect to mains 3. Turn on player with remote. 4. Press ENTER on remote. 5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 2 6. Press ENTER on remote. (The tray will open and player will power off and close tray.) 7. Switch on power from remote. 8. Player is now Region Free. Allows both region 1 & 2 DVD's to play.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Anonymous
  • 350 Answers
  • Posted on Oct 26, 2009
SOURCE: i cant play any discs on my samsung ht x200 due to
Go through the set up menu on the Ht DVD player (if it's all in one) and change your settings for the region code. Obviously it is not the one that you have already set it to (probably set by manufacturer). NTSC, PAL, etc. I hope this helps.
2answers
Play mp4 and mkv on samsung ht-z120 dvd player
I use the GomPlayer which you can get here. http://player.gomlab.com/eng/download/
This player works great I have no problems with it and it plays MKV and MP4
2answers
Need codec used by Samsung phone SCH M282C to install on my PC--help
What is the extension of the video? .mov .mp4 ? Download VLC media player, it can play almost every video format. http://download.cnet.com/VLC-Media-Player/3000-13632_4-10267151.html?tag=main;pop
2answers
Hi, I cannot play some .mkv files on my Samsung LN40C530. What could the problem be? Regards, Charles.
MKV is a video container format which may contain various video or audio codec. If the video or audio codec is not supported by Samsung, it will fail to play mkv files on Samsung.
To play unsupported MKV files, it is better to convert MKV to MP4 H.264 with the help of Avdshare Video Converter.
1helpful
2answers
I have no sound when playing mkv file
You need a video code to support your Media Player to replay MKV format. I remember when I installed Leawo Free MP4 Converter, it will let you choose a codec package, after that, I can use WMP to replay MKV file well. I think you can try it.
1helpful
5answers
I am unabLE to play mkv filEs
You can install Leawo Free MP4 Converter, when you install it, it will ask you to install a codec package, after you finish it. you can convert your video to MP4 format easily, or just watch your MKV video with Windows Media Player.
2helpful
3answers
Windows Media Player cannot play the file. The Player might not support the file type or might not support the codec that was used to compress the file.
Here's a link for CCCP, it's a codec pack which should take care of all your needs, I did a quick search to make sure it's still clean of viruses/spyware and it seems it is
CCCP
you may still need haali media splitter to play .mkv files in media player so here's a link and the link to the .mkv site:
Haali - direct download
.mkv site - main site for the matroska format (.mkv)
if all else fails use vlc, it plays anything, if it doesn't play in that then it won't play in anything
http://www.videolan.org/vlc/download-windows.html
I used to use all of these when I used windows and still use vlc now.
1helpful
3answers
MKV codec for GOM Player
You can't add codecs to GOM Player - they are enbedded.
Use instead VLC, this player truly supports pretty much everything.
2answers
Codec for mkv file
An MKV file is a Matroska file, you can download the codec @ http://www.free-codecs.com/download/Matroska_Pack.htm
or
You can install the latest VLC Media Player, here which will play mkv format.
Hope it helps.
2helpful
5answers
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
