There are different models with different ways to install the bag. The most common one is where the bag just pushes over the tube where the dirt comes into the dust compartment. Some have a paper bag inside a cloth bag with a variety of ways to attach the bag. For instructions on your specific model please include your model number.
Make sure its unplugged, flip it onto its front on some paper or cloth. Look at the base moulding and note several small screws hidden down in recesses. Get a Torx or Phillips driver as required and remove them to release the base moulding. Find the damaged roller drive belt, replace and reassemble in reverse order. Take care to ensure the roller and base cover are correctly located otherwise the roller will jamb. If it fluffy inside, take this opportunity to clean it out.
Remove the small screws on the bottom of the powerhead. On some models there are 2 hidden beneath the rubber wheels in front. Just pop the wheels out with a flat blade screwdriver and remove those two as well. Remove the hood and you have access to the belt, motor and roller. Here's the correct belt: http://vacuummedic.com/product.php?id=86
To change the belt on a Hoover Flair Stick Vacuum, remove all 6 screws from the bottom of the beater bar. There are 2 screws hidden under wheels. You must pop the wheels off with a screw driver to remove the hidden screws. The cogged belt is on the left side of the beater bar. Be careful not to pull the wires.
Hmmmm, Check bag you say. The manual for this machine shows it as a bagless model with a dirt cup that you empty. Is there an option for this machine that the manual doesn't show?
there is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
