Dell Inspiron 1000 won't turn on. It is always plugged into the electrical outlet. Cord is warm, outlet works. Held down power button for 30-40 seconds, still nothing. It worked fine last night. Could it be the battery, even though it's a rechargable battery - could it die? But it should turn on regardless because it's plugged into an outlet, correct?
Well if it is always plugged to the wall then the laptop's power jack is the common problem there. You can have a Computer Technician check it and diagnose it for you. Be careful how much you pay, if that is the problem (i'm pretty sure it has to be) you can shop for the part online (ebay is a good place to find them for around ten bucks) and hand it to the computer guy. Otherwise you may be charged a fortune to get it fixed. Next time, use a power surge between the power adapter and the wall's power outlet.
Here's is a brief explanation of what happens with the power jack. Inside of it there are two or three pieces of metal that look like thick wires and what they do is transfer the current to the laptop. Eventually they wear out and break (common cause is having your laptop plugged to the wall continously exposing it to all sorts of power surges). Hope it helps, good luck.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
According to your problem, this may occurs for either the
battery of your laptop or the charger is faulty. First check electric outlet where
you have plugged your laptop charger is OK. Then check the power cord. If
everything OK then you have to change the battery.
