Question about Canon ES-E1 EOS Link (4593a006) for PC
Problem with Zoombrowser EX Digital Camera software. I've downloaded Zoombrowser EX to my computer...disk from Canon camera purchase. When I click on the icon, I get "class not registered". Some background: I've been using this software succesfully for a couple of years. I got a new Canon camcorder which had the Digital Video software I downloaded. That's when the problems started. I've removed the Zoombrowser Digital Video software and reloaded the Zoombrower Digital Camera software. Still getting the "class not registered" message.
  • Anonymous Jan 05, 2010
    Tried your solution...still doesn't work.
Anonymous
  • 532 Answers
This is a registry error. Try this: type regsvr32 quartz.dll in the run box on your computer. That would be: Click start, run, and then type this into the box.
If yoou do this correctly, you should see a message that it was registered correctly.
Try the program to see if it fixed the issue.
Posted on Jan 04, 2010
  • Anonymous Jan 06, 2010
    Try this:
    Go to CanonUsa.com and download the most current version of The Zoombrowser software. It is an upgrade so you have to have the disc version installed on your PC.
    Run the download. See if this resolves your error.
    If not: Try a complete uninstall of zoombrowser and reinstall it, then run the upgrade.
    I hope this works for you.
How do I install the ds 126071 0n my laptop?
Although the manual does not show how to connect to a computer, the system map shows how to use a mini USB cable to connect the camera to a PC. But before the camera will communicate with any PC or Laptop, it needs software.
From the Canon USA website you still can download the Zoombrowser EX software for free. It used to be the EOS Digital solution disk and the ArcSoft PhotoStudio Disk.
Before connecting the camera, install the software. Then when software (and driver) are installed, when connecting the camera, the software will start up and ask what to do. Like import the pictures to the computer.
Success
Video from Canon GL2 to my sony vaio windows vista and I already updated to zoombrowser EX 6.1
Suggestion: Remove the memory chip from the Canon and get a reader that plugs directly into your USB port on the vaio. Available online or at any computer shop or big box store. You should be able to open the photos directly from the chip. They'll be in a DCIM folder - you may have to easter-egg around a bit, or search for *.jpg
Lots faster and less frustrating than the camera's software interface.
I have a new Dell Inspiron with Windows 7. No matter what I try I can't load/download a driver for Canon Ixus 300. I have the CD, but it is not compatible with Windows7.
Your CD is for an older version of Windows and the installers/drivers have changed over time. The driver you need is part of the Windows 7 OS so you should be able to just connect the camera to the computer using the appropriate USB cable.
The software update for the ZoomBrowser EX is available here: http://software.canon-europe.com/products/0000484.asp if you need. Use the drop-down menu to select Windows 7. Download and save the file. Then launch the updater (double-click) and insert your CD in the optical drive of the computer. Then follow the on-screen directions to install the ZoomBrowser EX version for Win7.
You can import from the camera with Paint (File > Import from Camera or Scanner) and PhotoGallery (if you have the Windows Live package installed)
I hope this helps.
2helpful
Trouble with downloading photos
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. The card reader doesn't care what camera took the pictures, so you can use it with any camera (assuming the card itself fits).
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Zoombrowser not working- not able to download RAW images to computer
Make sure you turned the camera on. Could be a bad cable. Best thing to get is a usb card reader. Some people report problems of bent pins because of removing and reinserting them in the camera. So be careful there. Re-Install the software that came with it from Canon. Or you can download it from CanonUSA. URL below.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=314&modelid=14256
choose your OS and download what you need.
Looks like ZoomBrowser is up to 6.1 now.
New computer. No Canon sofware. Canon Rebel EOS purchased second hand. Where can I get the software to download the pictures?
Hopefully you have the EOS Digital Rebel. (The EOS Rebel was a film camera.) Without the software that came with the camera (ZoomBrowser EX for Windows or ImageBrowser for Mac), you can only download JPG images using the PTP communication mode. The communication mode is set up in the Menu system on the camera, and is either "Normal" or "PTP". If you want to download RAW files, you will need to use a software application that has a converter for Canon RAW files (Photoshop, etc.). If you didn't get a User's Manual, you can get one here.
Another zoombrowser problem
You can use microsoft scanner and camera wizard to download in the meantime. I'm not sure what is going on with your Zoombrowser software. Which Operating System are you running?
5helpful
2answers
Canon zoombrowser Ex downloading problem
Try updating the Zoombrowser software.
If you have a connection to the camera, go into my computer and get images directly off the camera using scanner and camera wizard, microsoft's default program. This will at least allow you to transfer your images until you can resolve the software problem.
If you have no connection to the camera via your computer, you need to try some other troubleshooting steps to get a connection. I will post those below in the next post.
Help
Hi attache the camera to computer scan anti virus and try to download pictures
Canon ES-E1 EOS Link (4593a006) for PC Logo
Top Canon Computers & Internet Experts
old marine
old marine
Davit Mamyan
Davit Mamyan
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
