Question about HP Photosmart C5180 All-In-One InkJet Printer
Display says error 0xc05d1281
Display says ink system has failed
unable to print error 0xc05d1281
Posted by baliliorchid on
Buddy Mcsparrin
  • HP Master
  • 1,684 Answers
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 03, 2010
1 Related Answer
elix0411
Jose Cada
  • 3530 Answers
SOURCE: ink failure error OXc05d1281
Reset the system by holding down the OK, Cancel, Black, and Color buttons at the same time and turn the 3310 off. You should keep holding the buttons down until the printer shuts off and then turns itself back on. Turn the printer off twice for the printer to recalibrate. Make sure you have new cartridges in the printer so that it can reset.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Posted on May 12, 2010
Printer
Hello Jean,
Here is a link to a reset guide that should get you back up and printing in no time at all.
http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/
Feb 18, 2013 | HP C6280 Photosmart All-in-One Printer...
HPPhotosmart 3210 AIO hangs us with error code of 0xc05d1281
Hi Minnie,
This could be because of residue on the Printhead electrical contacts
Try the steps below and it should help.
Turn off the Printer.
1. Open the Carriage access door.
2. Remove the Cartridges
4. Move the carriage from left to right 6 times and it should move freely
5. Clean the contacts on the Cartridge with lint free cloth. ( Golden dots )
6. Turn on the printer and it should say " Cartridge missing or need to be reinstalled "
7. Install the Cartridges and close the Carriage door
8. the printer should go through alignment process
If this step does not fix, You may try calling HP customer support to check for better options/solutions
HP Customer Care : 1-800-474-6836
Regards,
Sean
Feb 16, 2013 | HP Photosmart 3210 All-In-One InkJet...
Ink failure error OXc05d1281
May 12, 2010 | HP Photosmart C8180 InkJet Printer
0xc05d1281 HP-C7280 Ink System Failed -- tried clearing the error status still same problem, also noise from the print head sounds like plastic gears sliping, print head moves back and forth gears slip and...
printer did not tell about empty cartrigde it just showed that the black was low but not empty -- decided to replace the cartridge early and that ficed the problem!! ?????
Oct 19, 2009 | HP Photosmart C7280 Laser Printer
How to take apart HP photosmart D7360
My HP D7360 won't print. Its says the "ink system has failed. Unable to print. Refer to printer Doc. Error: 0xc05d1281" Now, I lifted the printer up and it sounds like a screw bouncing around on the inside. How do I take this thing apart to find the screw and put it back in it's place???
Aug 27, 2009 | HP Photosmart D7360 All-In-One InkJet...
Ink System Failure with error code: 0xc05d1281
I had the same problem and took Guru NinaE advice....1. Unplug power cord from back of printer while it is on. 2. Wait for 60 seconds after it is in sleep mode. 3. Press and hold "Print Photos" and "Red Eye Removal" at the same time and while holding the two buttons down, plug in the power cord into the back of the printer. 4. The printer display should go blank or Reset might show up on the display. When this happens, touch the ON button and the printer will reset itself.
May 20, 2009 | HP Photosmart C8180 InkJet Printer
Ink failure
put ink cartridges in the printer
Jul 20, 2017 | HP Photosmart C7280 Laser Printer
Ink system has failed
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Jul 18, 2008 | HP Photosmart C6100 All-In-One Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
2,767 people viewed this question
Ekse
efs_perpends
efs_perpends
