Question about Agfa FUJIFILM FINEPIX Z33WP Digital Camera
Error when trying to save pics from camera onto computer
When i plug it into the computer via the usb cable supplied finepix viewer opens but says I/O error occurred process aborted - so i can't download the pics off my camera onto the computer!
Posted by rachela024 on
Anonymous
Get a new computer a good idea
Posted on Jan 03, 2010
How to get my pics off my blackberry, keeps saying pics are in mass media storage, where and how do i get to them
Plug your blackberry into your computer via usb cable and open your picture/camera viewer program and choose import..
Mar 05, 2014 | Cell Phones
USB COMMUNICATION ERROR
Use a card reader to download your pics to a folder you create on your desktop.
Oct 20, 2009 | Fuji Finepix J100 Digital Camera
Communication error
Sounds like you have corrupted or possibly deleted a Fine Pix Viewer driver software file.
Suggest you uninstall and reinstall Fine Pix Viewer.
Before you start you might want to create a backup folder on your C drive and put copies of all your photo files therein. Make sure your camera is not connected to your PC before reinstalling software.
Assuming Windows operating system click : Start, Settings, Control Panel, Add or Remove Software, then scroll to Fine Pix applications. You will probably have three to choose from. Since you don't know where the problem lies suggest you start with Fine Pix Viewer which will probably have a version such as 5.5 (in my computer anyway). Having highlighted this file click on the uninstall button.
Now reinstall from your Fine Pix CD.
Suggest you reboot so new software will recognise your camera when it is connected. With camera connected Windows will probably advise that there is new hardware and it is seeking software. Give it time and Viewer should boot up on your screen.
Jun 12, 2009 | Fuji FinePix Z100fd Digital Camera
Computer won't read camera or card
Do you have a suitable photographic program to view your photos installed such as Photoshop,Picture viewer or something? Have you installed any software onto your pc which was supplied with the camera? There is probablyl a compatible program supplied in this. Do not reformat unless you are prepared to lose your photos! Get a spare memory card to experiment with-one with no important photos on it! Make sure you install any camera software onto your pc.
Jun 11, 2009 | Fuji FinePix A360 Digital Camera
"SAVE WIZARD PICTURE" does not launch
yes i think u all are having problems in fuji fine pix viewer i think this peace of software is not updated with vista OS so nothing to worry just try alternate source to do this
just connect usb cable supplied with camera and connect ur camera it will show up as a removable disk in my computer open it up and download the pics if u have trouble doing it , first check if ur camera is set to PC = webcam mode and other mode icon means file transfer mode u need to select this mode from menu>setup>usb mode and then go download the pics on pc as described no need for drivers
if u have trouble i can arrange for pics to do that with a diagram
if anything else i can help
pls rate me fixya if i have fixed ur problem
Feb 13, 2009 | Fuji Finepix Z20fd Digital Camera
I/O Error process aborted when opening finepix viewer to download
I had same problem...Deleted Finepix software and used windows media player automatic plug and play...better program and uses less hard drive space :) (im running Vista Ultimate)
Dec 05, 2008 | Fuji FinePix Z10fd Digital Camera
What do i do
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
Cannot upload pics from camera to PC
Hi Ray;
Try uninstalling the Fuji software completely, through the Windows control panel. Don't use the supplied software at all. Make sure the camera is unplugged from the computer. Open "my computer" and note which drives are present. Now plug in the camera (still turned off) to the USB port. Turn the camera power switch on. Wait and see if a new drive icon shows up. It may take a minute or so. If you get a new icon (probably Fuji DSC or similar), you should be able to open the new drive and access the images through the various folders. If not, can you see images on the camera screen (when not connected to computer)? If yes, maybe a bad cable. If no, could be corrupted images on card.
Feb 05, 2008 | Fuji FinePix S700 Digital Camera
Can't upload pics to computer
Well..thanks for help. I got absolutely no help from Fuji customer support. I ended up taking the camera back and getting a different kind. Got a Sony Cyber-Shot and I love it!
Dec 29, 2007 | Fuji FinePix S700 Digital Camera
Agfa FUJIFILM FINEPIX Z33WP Digital Camera Logo
213 people viewed this question
Top Agfa Cameras Experts
Larry Stiles
Larry Stiles
Marvin
Marvin
Harrie
Are you an Agfa Camera Expert? Answer questions, earn points and help others
