Apple iPod Photo MP3 Player Logo
Question about Apple iPod Photo MP3 Player
ONly apple in the screen ??? Naw what to do ???? :-(
Posted by aleksa_89_kv on
Anonymous
  • 82 Answers
CONNECT YOUR IPOD TO YOUR PC AND TRY TO FORMAT IT ...IT WILL HELP ALOT. THANKS :)
Posted on Jan 03, 2010
My screen is green or red when i start up i have to push the screen right back and forward a few times than every naw and agane to get it normal.
There are a number of problems that may cause the screen to have intermitent problems like this.
1) There could be a faulty/loose connection between the screen and the laptops motherboard. The laptop would need to be taken apart and the connectors reset/replaced to see if that remedies the problem.
I suspect this is probably the problem as when you are moving the screen backwards and forwards you are probably remaking the connection
2) There could be a problem with the screen itself and may need replacing.
If you are confident you could repair this yourself, alternatively take it to a local computer repair shop. Shop around a few and get quotes off them before going with the first one you find.
Bought my ps3 when it came out been really good till naw . it will switch on disc will go in everything sounds like it works but i get no picture tried a new scart lead and still nothing.
  • If the video output settings on the PLAYSTATIONĀ®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATIONĀ®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • This is from playstations website Hope this helps.
    I FORGOT MY PASSWORD ON MY IPHONE AND NAW IT SAY ON THE SCREN CONECT TO ITUNES AND NOW IAM TO CONEC TO ITUNES YOU THINK IS GOIN TO WORK?
    You need to have a carrier sim in which your iPhone is locked to. Or you can try to jailbreak it and unlock.
    Check out my guide from eBay: http://cgi.ebay.com/JAILBREAK-UNLOCK-IPHONE-3G-IPOD-TOUCH-iOS-4-0-2-4-0-1-4-/320576101949?pt=PDA_Accessories
    If you need online help about jailbreaking and unlocking, you can contact me personally at this email: [email protected]
    2helpful
    How do I Unlock Ipod screen if I forgot the 4 digit password?..pls if ne1 knos d solution contact me pls.... ma id.: [email protected]
    Hold down the center button and the menu for 8-10 seconds until the apple logo appears. If you then quickly hold the center button and the previous song button the apple logo should "flip" and enter diagnostic mode. This may take a few attempts, but the initial reset should clear up the immediate issue of it being locked.
    At the bottom of the diagnostic menu there should be a "reset" option which will do a factory reset. You will lose everything on the iPod but you will not have it locked anymore.
    I HAVE ACTIVATION KEY BUT IT IS NOT ACSEPTED BY WINDOW 7. ULTIMATE WAHT CAN I DO NAW
    You need to do the activation by phone. Follow the screen instructions.
    My dvd is not going in dvd drive?????
    Well I know this seems obvious but is the PC on while you are trying to close the drive? Restart PC and push the button as soon as you see something on the screen. Most drives can be closed manually a few times without injuring the ejection motor. Try this and if it doesn't work then the drive is probably jammed in that position from something brushing up against it while it was out... Just play with it gently until you get it to go back in.
    2helpful
    4answers
    I can“t conect my web cam
    how to conect other web cam
    5 cd changer
    theres ur problem..its a wal*mart radio...rofl...naw, but does it play CDs...or the 2 it broke are the only 1s u dared put in it?
    Top Apple Audio Players & Recorders Experts
    woodzowl307
    Marvin
    Marvin
    W.L.
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
