I get a similar issue from my Bush sound bar. The sound drops out when the tv programme/movie etc has a period of silence in the audio track or just very low background music (no speech). As soon as someone begins to speak it starts up, but usually it misses the first couple of words. Bar is connected directly to a Samsung tv via the optical cable. Any ideas?
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Make sure that the DVD player is connected into the correct inputs on the receiver and that the receiver also has the correct input selected to play. If your TV also has component video inputs it is best to connect the player directly to the TV. Otherwise, make sure you have the TV connected to the receiver via component video out.
I can't imagine your setup. Box, tv and pc speakers? Typical setup would be box, tv and some kind audio system with optical IN. Correct wiring would be connect box to tv via scart and connect optical cable from BOX to audio system. You have to go from box not from TV since scart connection doesn't carry audio signal. To have TV to output optical audio out you would have to connect it to box via hdmi.
Hello All, I discovered the same problem when connecting my LCD TV LE40R8 to my HT-X30. I reported the problem to Samsung this morning and they told me that they are aware of the issue (which is with the TV) and an automatic software update to resolve the problem will be sent out to the TV early in December. You should get an automatic update message on your screen, just follow the instructions and this should upload the fix. Fingers crossed!
