Question about Coship CDVB2000E
We dicovered program BVN scrambled and low quality 35% signal
Scrambled program ( BVN ), signal strength 75%, low quality 35% on Optus D2 many other programs are fine, but the programs close in frequency to BVN show the same problems however not all are scrambled. I am located in North Tasmania- Australia. Previously we dit not have to many problems! We use a Star receiver type CBVB2880A.
Have a look of you can help.
Regards:
Arend
Posted by arend2 on
Donald Pera Deane
  • Coship Master
  • 384 Answers
Sounds like You are not in the right area to receive signal at 35% is not good it may be geo blocking most satellites will not broadcast to other countries more info would be appreciated!!'
We Are Here To Help !!
Posted on Aug 12, 2017
2 Related Answers
Anonymous
SOURCE: Re-programming for Optus D2 satellite
what brand of set top box do you have?
Posted on Feb 05, 2008
Anonymous
SOURCE: scramble
how to unlock channel on fortec star fs4200
Posted on Jul 26, 2009
If i have a smart tv, do I need a booster for an outdoor antenna, I am planning on a 20-30ft pole, for the antenna
The benefit and functionality of a smart tv is derived as much from a good internet connection as from decent signal strength from the antenna.
The ideal height, type and direction of the antenna depends entirely on the signal strength available where you are and the length and type of downlead cable.
If the signal strength is poor it is generally better to use a high gain wideband aerial designed for fringe reception than to use a lower gain and a booster.
It is worth noting a booster can usefully help increase the strength of a weak but good quality signal but there is little advantage boosting a signal that is both weak and poor quality so it is best to obtain the best signal possible before considering a booster.
A low specification downlead can reduce the signal and gather interference causing a bad signal/noise ratio. Using a booster at the end of such a downlead will boost the interference as well as the signal - the best place for a booster is as close to the aerial as possible and masthead types are produced to avoid those types of problem.
It is best practice to use the highest quality downlead cable - double wrapped air spaced low-loss 75 ohm coaxial cable.
Jul 09, 2018 | Televison & Video
I have an Icom v-8000 radio.The TX is very good with 75 watts out-put. But have nothing in RX.No signal and no audio.
What you have is an amateur band radio, which requires you to be a licensed operator to use it. It is possible that the frequencies have been removed from the eeprom prior to your purchasing same.
You can have Rx only frequencies programmed by an authorised 2-way workshop, but until you become a qualified amateur operator, you will not be able to get Tx frequencies programmed.
For licensing info for Amateur operators visit www.vk6wia.org.
Regards,
Peter
Feb 20, 2013 | Radio Communications
Optus won't accept my unlocked telstra samsung sgh-a412, why?
Contact OPTUS Email 1-800-383-368 Number For Technical Support
In Case You have any Difficulty while using OPTUS Email then Call Help Desk Australia.
OPTUS existing Email Service in Australian Region. It links Users from widespread. We recommend round a clock Support with my licensed Specialists. Our Team is Forceful and they provide support to the clients at no time. They offer high-class service.
Have Any Difficulty in OPTUS Email?
1. Troubleshoot
2. Configuration Errors
3. Sent and Receive Email Problems
4. Unwanted mail in Inbox
So, These Issues are happening in OPTUS Email. Our main objective is to offer High-quality service to our Consumers. We give Instantaneous Reply Service to the consumers through Phone Number. We have well Qualified specialist which provide 365 Days Support to the consumers. If you have any difficulty then Phone up OPTUS Email Technical Support Phone Number Australia For Quick Support.
1-800-383-368
https://www.helpdeskaustralia.com/optus-technical-support.html
May 25, 2017 | Computers & Internet
I get about 68% signal strength yet I cant get audio/video on etv south Africa. How can this be corrected?
Hello
You have 68% signal strength OK. What about the signal quality? Check it please. Signal quality must alos come near to 35% at least to get good picture and sound. 50 to 80% is better. Check out it.
Nov 19, 2010 | Televison & Video
I don't have the manual for my Uniden Bearcat BC 855 scanner.
You can download/print the complete manual for your scanner by following the link below. It's a free download, and it provides detailed programming instructions. If you're programming a channel that is "empty" (showing 000.0000) just enter your frequency. Empty channels automatically show LOCKOUT but it clears with programming. The squelch setting will vary according to the strength of the signals you receive. Once you start scanning, turn the squelch down until scanning stops and you hear a hissing sound, then turn the control up slowly until scanning resumes.
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Dec 30, 2009 | Uniden BC248CLT Base Scanner
Humax 8000T not used for a while, now says ''no or bad signal'' and says no channels available when it searches.I tried resetting to default settings but still no joy. When I checked signal status it says...
sig strength 29 is too low to lock onto. Humax needs 50+ to lock ideally 65+
is the aerial ok? try the set on someone elses aerial. If no joy then its possible the tuner is duff...but thats virtually unheard of.
Oct 24, 2009 | Humax Televison & Video
I had a linksys "g" router hooked up to a wireless desktop and a PS3. i got about a 65-75% signal strength on both.my online gaming was fine, but i would start the matches late and sometimes have a...
The lag could be because of a latency between your router and the gaming servers you are connecting to. Not a whole lot you can do about that.
FYI, signal strength of 65-75% isn't bad at all and shouldn't have a significant impact on your wireless performance. Keep in mind that your internet connection is usually the bottleneck for performance. If your wireless runs at 54Mbps with 100% signal strength, when you lose signal, it reduces the performance of your wireless. For example, if you were to get to 40% signal strength, your performance could be reduced to only 11Mbps. While that is a drastic drop for your local LAN performance, 11Mbps is still faster than the vast majority of internet providers currently have, so your in-game performance shouldn't change, based on less signal strength or less bandwidth.
As for your "N" router, if you have a 5Ghz or 2.4Ghz cordless phone in the location where you installed the router, there is a chance that it is conflicting with that frequency. Since you don't have that problem on your "G" router, I can only deduce that if this is the problem, you have a 5Ghz phone, since "G" operates only at 2.4Ghz. If you still have the "N" router, disconnect the phone, re-install the "N" router and see if that fixes your problem. If it does, then you may want to either stick to the "G" router anyway or upgrade your phone to the newer "wireless friendly" 6Ghz phones.
Aug 29, 2009 | Linksys Computers & Internet
Cordless phones
Being on two unique frequencies, they should coexist happily on the same phone lines, but avoid putting the base units in "too close" proximity of one another... Harmonic radiations (Radio Frequency Interference at multiples or fractions of the carrier freq.) are more pronounced and problematic at close range. So try and isolate base units as much as feasibly possible. A transmitter on one frequency can overload a too nearby receiver's initial frequency filtering ability via blunt force of signal strength. Signal strength drops exponentially by distance so a little space increase can make a big difference. Three to five feet separation is usually adequate, and depending on how well designed and well tuned the indivual units are, they might possibly work fine right next to each other... But if they don't, separate 'em!
Jun 02, 2008 | Uniden Cordless Phone
Jan 24, 2008 | Coship CDVB2000E
Is it the DCT or the cable signal?
if you are getting signal of the proper strength and quality the cabling is good.the problem is the box trying to decode the signals.a lot of signals are encripted and have to be decoded by the box.if the box is not responding fast enough you will see bloches on the tv.if you see scrambled channel you are not payinfor that channel.and if you are paying for a channel and it comes up scrambled your box is not working correct.get your company to upgrade the box.
Jan 07, 2008 | Arris DCT6200 DTV Receiver
Televison & Video Logo
102 people viewed this question
Top Coship Televison & Video Experts
Marvin
Marvin
Are you a Coship Televison and Video Expert? Answer questions, earn points and help others
