HP Compaq Evo Notebook N600c Logo
Anonymous Posted on Jan 03, 2010
The DVD drive in my wife's Compaq Evo N600C has stopped reading CDs. It reads DVDs fine, but doesn't recognize any CD or CD-R.
  • 6 more comments
  • Anonymous Jan 03, 2010
    Since the problem first appeared, she has installed several software downloads, and I recently upgraded the machine from Win 98SE to Win XP (I had to make a backup copy of the install CD on DVD media to manage that!), but that didn't solve the problem. Checking under Start >Control Panel > System >Hardware >Device Manager shows no yellow triangle and indicates the DVD drive is working properly. I've tried using TWO CD lens cleaners, to no avail - the machine still reads DVDs but no CDs.
  • Anonymous Jan 04, 2010
    I don't think we have, yet, but I don't see the relevance, since we're not having problems with DVDs, and the problem started when she had 98SE on the machine
  • Anonymous Jan 06, 2010
    The UpperFilters and LowerFilters strings are not present under that registry item, nor does the file PxHelp20.sys exist on the computer. I ran the HP/Compaq diagnostics; the CD drive tests work fine when there's a DVD in the system, but with a CD they report no media present.
    System ROM has been updated to the latest available version, also.
  • Anonymous Jan 07, 2010
    You may well be right. Today I did a search on the specific rebadged Toshiba drive model with the result that it is a known problem with the particular model - and a suggested cure has been posted elsewhere on this site, involving tweaking an internal potentiometer on the drive. Since replacing the drive is impractical at this time, I'll give that a try.
    Tweaking the pot controlling the CD read "eye" did the trick. CDs are now being detected and read properly.
  • Anonymous Feb 03, 2010
    This turned out to be a hardware issue - the sensitivity of the CD detector needed adjustment.
  • Anonymous May 11, 2010
    Did you download and install the WinDVD Player Version 1.4, 2.4, or 3.0. update for customers who have upgraded one of the Compaq EVO notebook models to Windows XP?http://h20000.www2.hp.com/bizsupport/Tec...
    Have you installed any new software lately? If yes, what was installed? Have you changed or upgraded operating systems? Go to Start >Control Panel > System >Device Manager. Look to see if there are any yellow triangles.
Anonymous
Level 3:
President:
  • Master 287 Answers
  • Posted on Jan 03, 2010
Anonymous
Master
Level 3:
President:
Answers
287
Questions
0
Helped
104989
Points
1292
1. Right-Click on My Computer -> Properties
2. Click on Device Manager.
3. In the list of devices, click on CD/DVD Drives.
4. Select ur CD/DVD device and right-click on it.
5. Check the Device Status (Working Properly)!
6. If required, You can update / uninstall / rollback the driver for this device by clicking on, Driver option.
7. Apply settings and close dialog box.
8. Restart the system.
if it helps tell me....tc! :)
Steve Sweetleaf
Level 3:
  • HP Master 1,212 Answers
Steve Sweetleaf
HP Master
Level 3:
Answers
1212
Questions
5
Helped
433176
Points
3475
Try a good cd lens cleaner they work well may solve it.
  • Steve Sweetleaf
    Steve Sweetleaf Jan 04, 2010
    If your winXP check your registry under: HKLM\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
    if there is a string labeled either UpperFilters or LowerFilters.
    If either of these mention "PxHelp20.sys" remove it. You should see
    results almost instantly.
    Another way to look for this is to go into device manager and look
    at the properties for the drive in question. In the driver tab see if
    that file is mentioned.
    If you have vista it might be the same, but if not try running a search in your registry for this file.
  • Steve Sweetleaf
    Steve Sweetleaf Jan 06, 2010
    cd drives have 2 different eyes one for the dvd and 1 for cd,im guessing that your cd is not being picked up by the cd palyer. because theoptical eye for cd is not working i would try another cd/dvd player..ive seen this many times and it usually ends up being the cd eye has malfunctioned.
2helpful
2answers
Dvd rom doesn't work
try to clean the dvd rom drive by a lens cleaner...
Dvd writer stopped reading cds even at boot up
try autofixer from microsoft offical page.if doesn"t work
http://www.microsoft.com/downloads/details.aspx?familyid=C680A7B6-E8FA-45C4-A171-1B389CFACDAD&displaylang=en
1helpful
Can operate with CD ROM's. Won't recognize DVD's.
Sounds like the drive could be going bad. The way the laser reads DVDs vs. CDs is different, that is why you are able to read one, not the other. I had this happen to me, except the opposite. It could read DVDs, not CDs. Had to buy a new one, and all is well.
Suddenly stopped reading cds but reads dvds
Could be a bad drive, as DVD lasers are a little different than just CD lasers. The laser may be bad for one, but the other can work. I had this issue, had to buy a new drive.
2answers
Dvd rom not reading cds/dvds
I had similar problem on a Toshiba Satellite A30 laptop, I simply had to reconnect DVD drive. It usually loosing it's connection with motherboard and drive is visible in My Computer but it doesn't recognize any discs. If reconnection does not solve your issue you may try to update your DVD firmware and if it won't help replace DVD drive. Good Luck!
DVD drive reads DVDs but not CDs
Neither dvds or cds are loading,
How to or can't boot from a CD or DVD. If the computer is loading to an error message when attempting to boot to ... Not all CDs and DVDs are bootable; in order to boot from a CD .
Read and follow instructions, Good Luck please dont for get to Vote/Thank You.
2helpful
2answers
Not reading DVD
It's common problem with combo drives in notebooks, they don't seem to last long. Try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. If the problem persists the laser is faulty in the drive and the drive will need to be replaced.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
