SOURCE: VHS has audio but no video
we cannot get the vcr portion to work only the dvd player works what are we doing wrong?
Have the same problem? Click Here
Best Solution
posted on Oct 24, 2007
MikeNJ1964
Rank: Guru
Rating: 88%, 431 votes
On some of the DVD/VCR combo units, the VCR output is only available through the RF jack (channel 3), standard video
(yellow) RCA jack and S-VIDEO jack. If you are using the Component
jacks, the DVD side will work but the VCR will not. This is because
the quality of video recorded on VHS tapes is so much lower than
component quality video.
Thank you for rating this solution.
SOURCE: recorded DVDs will not play on other DVD players
make sure you finalize the disc very inportant!
SOURCE: go video dvd recorder vhs combo vr3845 - won't read discs - says unknown disc
FIRST UNPLUG THE UNIT FROM POWER !!!!! The problem is dirt/dust/****/crud/stuff on the tiny, little ***** laser lens. Remove the case screws ( 2 on each side, some in the back) with a correct size driver. The cover must be pulled open at the bottom, side to side a tiny bit ( use a hand on each side) to allow the cover to lift up at the rear, it must come up quite a bit as if it is hinged at the front and THEN pulled back out of the front panel. Set the cover to the side. The DVD reader/Burner is covered with a small black cover, it is held on with two TINY screws, STOP!!!! Get yourself the CORRECT size driver at Fry's or Radio Shack, DO NOT get cheap here!!! Remove the two screws and find the two plastic grip tabs, push them to release and lift the cover. There is the laser! It is a tiny blue lens about the same diameter as the tiny screws. find a very, very well washed CLEAN 100% cotton T-shirt. The softer the better, get 70% or higher rubbing alcohol, pull the fabric over the tip of the finger and wet with the alcohol. VERY GENTLY wipe the lens 4 to 5 wipes and the 3 wipes with a dry spot. That should clean the lens. USE NOTHING ELSE!!!!!! The lens tracks back and forth on two tiny bars. The stuff I use is WD-40 wet on a Q-tip swab. Go to a safe place to spray the WD-40 on the Q-tip. The lube should drip. With the Q-tip apply the lube to the tiny bars at the ponts of rider contacts and wipe the bars too. Put the top of the burner back> BE CAREFUL!! Use a magnet driver and then repower and try to read a known good dvd. You will have to do this more in the future, you understand, dist dirt etc in the air. Put the top back on. Enjoy.
SOURCE: go video VR4940 VCR video recording has sound but no picture
You can try cleaning the video tape heads. The vcr has 2 different heads. One for audio which is fixed and a drum head for video with 2 heads on it that rotate. The best way to clean them is to take a lint free cloth ad wrap it tightly around your finger. Put some alcohol on the cloth and place it on the drum. Then rotate the drum as you hold your finger against the drum. DO NOT move your finger up and down as you can brake the head off. The other option is to go buy a head cleaning stick. It's a piece of chamie on a plastic tongue depressor. I've cleaned hundreds of them with my finger though. You can clean the whole tape path with the rag. Good Luck.
SOURCE: Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
