Tag Heuer cj1110.ba0576 Wristwatch Logo
Posted on Jan 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tag Heuer date adjustment doesn't work. I pull the crown out one notch, turn it clockwise, and nothing happens. Turn in it counter clockwise, nothing happens. ???? The only way to adjust it is by adjusting the time, with two complete revolutions for each day adjusted. Any ideas?????
Anonymous
Level 3:
President:
  • Master 2,501 Answers
  • Posted on Jan 03, 2010
Anonymous
Master
Level 3:
President:
Answers
2501
Questions
Helped
1291856
Points
7081
The date change occurs at midnight, so winding it past midnight changes the date. To change it again wind the hands backward to (say) 11 O'clock) and then forward again will change the date again.
How far you need to turn it back will have to be found by experiment.
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • 0helpful
    Instruction manual
    Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps .
    4helpful
    2answers
    How do I wind up my tag carrera automatic using the crown??
    Wow, how wrong yall are.
    There are three positions for the Carrera's push-down crown. The inner position is used for normal wear and winding. To wind the crown manually, simply rotate it clockwise.
    Changing the date on the Carrera is done from the middle crown position. Turn the crown clockwise to advance the date, one day at a time. Push the crown back to the inner position when finished.
    The outer crown position is used for setting the time. You can turn the crown in this position either clockwise or counter-clockwise. Adjust the time forward or backwards. Setting the time backwards will not damage the watch. When the time is correct, press the crown all the way into the inner position.
    10helpful
    2answers
    How do i change teh date on my tag watch with out having to wind it 24 hours to change one day. i need to change 15 days
    If you pull out crown carefuly, you will notice there are two clicks. The first one is for adjusting calendar (day or/and date). Next one is for moving hands. Pull out to the first click and adjust the date by turning the crown.
    Rate me, please.
    4helpful
    Help setting the time
    Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
    3helpful
    Tag Heuer Ladies Professoinal 2000
    Hi Dude, it's one of those things your going to cuss once you know. Just unscrew the Bezel.Thats it. Steve
    How do i remove the crown on my DKNY 1094 2003 model
    nice noon to you ! you need to open the crown ,to open the crown , wind it counter clockwise until the crown lose then pull it and adjust the time after set the time ,push the crown and wind it clockwise until the crown fix tight,
    9helpful
    2answers
    How to adjust the date in tagheuer watch
    Some TAG models have a date "quick set". Pull crown out just a wee bit to position #1. Turn counter clockwise to advance date. Pulling out the crown to position #2 stops the watch and sets the time.
    33helpful
    4answers
    Tag Heuer Aquaracer calendar problems
    You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
    Top Tag Heuer Watches Experts
    k24674
    Sean Wright
    Sean Wright
    Ngoro
    Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
