Question about Canon Rebel XT / EOS 350D Digital Camera
Camera does not switch on, I have checked the battery which is OK and fully charged.
Could be internal fuse.........Tricky
Posted on Jan 03, 2010
  • Anonymous Jan 03, 2010
    Here is view of fuse location on EOS400D
My kodak easyshare 1063 will turn on
If you have a fully charged battery and still the camera won't switch on, you have to check if you did not put in the battery the worn way around. It is almost impossible, but still. Some people are stronger then others and manage to do so. Then you have to check if all contacts in the battery compartment are clean and shiny and not bent. Use a torch. The contacts are deep and small. If there is debris or oxidation on the contacts try cleaning it with a dry cloth or cotton swabs.
if that is ok, check if the memory card is in ok and also check the contacts of the memory card and in the camera. Everything alright, then close the battery / memory card door and check if it is closed correct. There is a switch that should indicate the door is locked. If the switch does not work the camera does not switch on. But you can't "repair" a door switch if it is not functioning correct.
Jul 06, 2014 | Cameras
1991 Toyota Pickup - wont start....battery is ok
faulty starter relay, faulty starter, faulty starter switch, (not to be confused with key switch), how do you know your battery is ok? it could lose its charge overtime/have a dead cell, might have enough energy for lights, but not a high draw thing like a starter. Make sure your battery has 12.5 volts, 13.5 volts being nice and fully charged. check battery connections at both ends, battery and starter ends.
Dec 15, 2013 | Toyota Cars & Trucks
Power switch not working
hello sir .. does your batteries are charged already??
if your batteries are fully charged and your camera didn`t turn on,
there`s a possibility that your camera has a problem. You can visit the store where you bought your camera and you can ask questions there why does your camera didn`t turn on whenever your batteries are ok .. :)
Feb 23, 2013 | Kodak EasyShare C142 Digital Camera
My camera won't turn on and it's not the batteries because i fully charged it. HEEEEEEEEEEEEELLLLLLLLLP !
You can check your battery with multi meter is that ok or not.Other way check with any friend camera You confirm battery is ok.As you says battery fully charged then must be problem with Main board. After confirm Battery ok you need to replaced Main board.Main board can be repair but need so Tool which is only have in service centre so go to your near service centre to fix it.
Oct 29, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Canon 300d flash won't fire. Pops up ok but display just reads "busy" and camera locks up. Must turn on/off to get camera working. External flash works ok.
This may sound obvious, but have you tried to make surer the battery is fully charged and then see'ing if it still does this? The reason I suggest this is that I had a similar problem and when I fully charged the battery this problem went away. I tend to keep an extra battery (fully charged) plus the charger on hand at all times.
Dec 09, 2009 | Canon Digital Rebel / EOS-300D Digital...
When I load fully charged batteries it comes up with the 'battery low' warning and sometimes 'zoom error'
Believe it or not, the batteries are not fully charged.
1. Use alkyline batteries to test if camera is ok.
2. Carry a spare set of alkyline batteries
3. Don't mix battery types or mA sizes
Sep 01, 2009 | Olympus SP-310 Digital Camera
Canon 400d new batteries installed but will still not turn on.
Might seem obvious but check that the green light on the charging unit showed that the battery was fully charged before you put it in the camera. Make sure that the memory card is fully seated in the slot. If ok then either the charger is not charging or the on/off switch is faulty.
Jul 14, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Switching off as if battery is depleted when the battery is newly charged
I called Pentax and they said it's a known problem and the lens needs to be re-synchronized. They said this is usually caused by dust in the lens.
I have to send the camera to : -
Pentax U.K. Limited
Pentax House
Heron Drive
Langley
Slough
SL3 8P
It's a free repair if you bought the camera less than a year ago o/w they will send you a quote for the repair.
Aug 22, 2008 | Cameras
Canon 400d will not switch on
it might be a problem with the battery connectors.
They might not touch the battery well.
another reason, it might be the battery is dead or the power button is not working.
Aug 20, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon Rebel XT / EOS 350D Digital Camera Logo
1,427 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
