NetGear RangeMax  NEXT WNR834B Wireless Router Logo
Posted on Jan 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i put a password on my netgear n router ,when i put the i.p address in which is 192.168.1.1 it takes me to the bt voyager 200 page intstead of the netgear page which would allow me to the password in,is their any other easy way to do it,thanx
Harshit Kumar
Level 2:
Scholar:
  • Expert 124 Answers
  • Posted on Jan 17, 2010
Harshit Kumar
Expert
Level 2:
Scholar:
Answers
124
Questions
0
Helped
36413
Points
269
U can try with www.routerlogin.com .
username : admin , Password - password
And on the left hand side blue panel , u will see setup password option .. so u can setup a password there
How do i find the security code for a netgearwgr614 router
For finding security code of Netgear WGR 614 router follow the steps-
1. Login the Admin.
2. Click on Advanced
3. Go to the Administration
4. Click on Set password
5. Enter old password.
6. Enter New password.
7. Repeat New password.
See in images:-
Not finding security code visit:- Netgear Router Tech Support Number
99 s 10
Please reset your router and enter gain using the default username and password.
The default username and password for Netgear routers are admin and 1234 respectively.
1. Open your web browser and type in your router's IP address. The default IP address for Netgear routers is http://192.168.2.1.
2. Enter your username and password once prompted by your web browser. The default username and password for Netgear routers are admin and 1234 respectively.
3. Select "Set Password" from the left hand navigation menu on the router's manager menu.
4. Type in the old password, which should be 1234 if it is set to default and then type your new password twice.
5. Click "Apply" and the new password will take effect immediately.
I have a netgear readyNAS NV+ that i want to reset the password.
Whether you bought a used Netgear router or just forgot your own password, you can reset it and start over.
This is not an unusual problem, so Netgear has made resetting and restarting their routers a simple task
Connect all of your devices.
If your Netgear router is not already connected, it should be plugged in, with one Ethernet cable connecting it to your computer and a second Ethernet cable connecting it to your computer's modem.
Locate the reset button on the rear of your Netgear router.
The reset button is a small inset button and requires a pointed object to reach it.
Use a fine-tipped pen to hold the button down for at least 10 seconds.
The test light should flash during this process.
Open your Internet browser and enter the Netgear router's IP address into the address bar to access the router's information. Generally, Netgear routers use the IP address 192.168.0.1, but the specific IP address will be listed in the router's manual.
Attempt to log in to the router with the default username and password.
The default username is "admin" and the default password is "password."
If the router's username and password were not cleared away, unplug the router and try holding down the reset button.
While you are holding down the reset button, plug the router back in.
Log in to the router using the default "admin" username and "password" as the password.
You can now reset your information, rename your router and enter your own username and password.
http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
How to find my pass work for wifi
If you are using AT&T as your internet service provider the password might be on the side or bottom of the Modem/Router of theirs. Look for something called Network Key or Network Password/Passphrase.
If it's a wireless router you purchased and installed then you will need a network cable to go from the router into the pc. If you have a desktop it might already have the network cable going from the router to the desktop then use the desktop. You'll need to get into the router's configuration. To do that you'll have to open up internet explorer then type the router's ip address into the browsers address area where you would normally type www. Normally the router's ip address will be something like 192.168.1.1 Once you are into the router the configuration interface will come up. It will ask you for the userid and password. Most times people leave these set as the default that came with it. Once you're in, go to the wireless and wireless security tabs and there you'll see your SSID (the network you connect to) and the Password.
If you don't know the router's ip address, userid or password, you can go to www.google.com and type in the manufacturer's name and support. For example if you have a Netgear Router type "Netgear Support" . On their site for your model number they will have a manual that you find find the info you need. In addition to the 192.168.1.1 type of ip address, Netgear also had something like Netgear.routerlogin
You can also just google "Netgear router ip address" put your router model in between Netgear and router to scale down the search.
You can also do the same thing to find the default userid and password. Just google "Netgear Router userid or Password".
How do I find my pass work for wifi
1helpful
How do i put a password on my ip address
You will need to reset your router to default settings, To warn you this will make your router unsecure simply press and hold the reset button located on the back of your router for 15 seconds or until the router resets. Here is a link to show you how to re secure your router and to put new password on your connection.
ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
1helpful
2answers
Cannot connect wireless device to netgear router lost password
when you try to log in to your router I assume it aske for a user name and password. If that is the case, then in the user block type in : admin
and for the password, type in : password
these are the default logins for most netgear routers, other brands have other defaults.
I had to use these myself, as I have a netgear router as well.
I hope this info offers you some assistance.
Put a blackberry phone on my wireless network and now the netgear router is asking for a securty key to get i pods x box etc on
To find the security password for your netgear router please follow these steps,
1. Use an Ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
2. In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
3. When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it.
4. In the left side click on Wireless settings , Under
I want to put password on my router netgear
do you have the manual, get the manual from netgear online and that will give you the default passwords and login.
select your router here: http://kb.netgear.com/app/products/family/a_id/1296
To access the router you use an internet browser and type the ip into the address bar, something like 192.168.1.1 then you logon with username and password. usually admin and admin for most routers. then in the settings you should find an option to set password
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
