Question about HP PAVILION DV4000 SERIES 100GB HARD DRIVE - 383488-001 CD-ROM Drive
When i turned on this hp pavillion dv4 the control center shows up and doesnt let me exit out.how do i fix it ?
Posted by josscazares on
Anonymous
    President:
  • 2,600 Answers
Go to the start button and click on the run box, type in msconfig and hit enter. When the windown pops up, click on "selective startup". Click on the startup tab at the top of the windown, this will list all programs and services that automatically start when windows boots. The only things here that you absolutely need to startup with windows is your wireless configuration, virus and malware protection, and touchpad software to enable tapping and scrolling and changing settings....most of the other programs you do not need to aytomatically start, they can be started when you need them and then you just click on their shortcuts. Go through these [rograms and see if there is anything listed as control center....if not look on the control center window and see if the is a small box in the left lower corner that needs to be checked in order for the windown to not sho up on the next boot. Either way, you can get rid of it in msconfig. Hit apply and ok and restart.
Posted on Jan 11, 2010
How fo i fix the screen on my hp pavillion dv4?
check out if it is due to RAM failure..
No boot on a HP Pavillion dv4-1428dx
The real problem is with your laptops GPU
read this article so you know what to do.
Your Laptop Stops Working But Why Does it Fail
If you want to fix it, take out the motherboard and send it to have it repaired. Its called reballing. Look for it in the internet.
good luck.
What's HP Pavillion dv4-1313 dx monitor does not come on
SEEMS THAT THE OS IS UNABLE TO BOOT.GET THE INSTALLATION CD AD BOOT THE SELECT REPAIR.
Hp pavillion dv4-1502tu, we can get motherbord of this laptop? how much cost it?
http://cgi.ebay.com/HP-DV4-1502TU-DV4-1503TU-DV4-1505TU-HDMI-MOTHERBOARD-US-/330572175177?pt=Motherboards&hash=item4cf7a31749
2answers
My hp pavillion dv4 sd card will not work
Hi
I think you can go to Hp website and go to support download and get the driver for it
1helpful
My wireless switch is not active,can you please help me
Hi There,
Here are the steps you need to follow.
First turn off and restart your computer. Then press F10 to enter the System BIOS Settings. Select F9 (Setup Defaults) and when it asks Load Default Configuration Now? , Enter YES. Then, press F10 (Save and Exit) and when it asks Save Configuration Changes And Exit Now, Enter YES. This should restore the wireless LAN button to its original factory settings. Once you restart the computer the button will be listed as disabled, but press on the button and it should work again.
Good Luck
Pavillion dv4 new battery only charged one time.
How long did you leave the battery for charging?
Computers & Internet Logo
Top HP Computers & Internet Experts
Ekse
Michael Thomas
Michael Thomas
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
